link3724 link3725 link3726 link3727 link3728 link3729 link3730 link3731 link3732 link3733 link3734 link3735 link3736 link3737 link3738 link3739 link3740 link3741 link3742 link3743 link3744 link3745 link3746 link3747 link3748 link3749 link3750 link3751 link3752 link3753 link3754 link3755 link3756 link3757 link3758 link3759 link3760 link3761 link3762 link3763 link3764 link3765 link3766 link3767 link3768 link3769 link3770 link3771 link3772 link3773 link3774 link3775 link3776 link3777 link3778 link3779 link3780 link3781 link3782 link3783 link3784 link3785 link3786 link3787 link3788 link3789 link3790 link3791 link3792 link3793 link3794 link3795 link3796 link3797 link3798 link3799 link3800 link3801 link3802 link3803 link3804 link3805 link3806 link3807 link3808 link3809 link3810 link3811 link3812 link3813 link3814 link3815 link3816 link3817 link3818 link3819 link3820 link3821 link3822 link3823 link3824 link3825 link3826 link3827 link3828 link3829 link3830 link3831 link3832 link3833 link3834 link3835 link3836 link3837 link3838 link3839 link3840 link3841 link3842 link3843 link3844 link3845 link3846 link3847 link3848 link3849 link3850 link3851 link3852 link3853 link3854 link3855 link3856
moar lowering a lowered 85t? advice plox
  • adroitcaptor
    adroitcaptor
    • 178
    I would like to lower my Z which I believe is already lowered; I am too poor ATM for coilovers. My current springs and shocks aresome kind of green lowering spring and adjustable illuminas installedby the PO. I would greatlyappreciate help in exploring a solution. (FWIW – I plan on goingcoilovers+z32 rear subframe+late turbo front end next winter or inabout 2yrs. I also have a pretty big metal/welding shop with a bunchof scrap metal.)
    I am assuming the front strut tubeand/or spring perch can be modified to lower the front end. I amgoing to look into this as soon as I get home.
    What about the rear springs? I believeI can just cut and rethread the piston arm/rod of the shock absorberand re-thread the end (as suggested in another thread). The springshowever, sit over the CV joint and it does not look like I can lowerthe bottom perch; how about the top?
    Any help would be greatly appreciated.
  • Trbulnt
    Trbulnt
    • 347
    So you want to physically modify the structure of the vehicle to acheive moar low when in 2 years you are planning on going with coilovers plus Z32 rear? What is your goal for this vehicle? What if you lower the perch too much and have no safe adjustment to raise it up? The "shock absorber" does not affect ride height, that is the springs job. The strut affects ride quality.
  • Careless
    Careless
    • 13279
    you could use lowering springs from a different car in the rear, and you can modify your strut tubes to accept the ground-control style coilover setup. most i've seen to have this done comes in around 400-500 dollars.
    i think most people would agree that saving up for some proper coilovers or at least waiting to see what the outcome of G-Es coilover adapters would be your best bet. you can then buy some used S13 or S14 coilovers and buy the rear adapter mounts for the strut tower/top mount. it would probably end up costing you close to 600 bucks to have a pretty well rounded coilover setup rather than 1200 for stance or powertrix.
    said and done the more expensive solutions are obviously a lot more easy to install and straightforward, as well as little to no test fitting required. but you can get away with a cheaper setup that may perform just as well.
  • adroitcaptor
    adroitcaptor
    • 178
    This is a vehicle that I like to pretend one day I will take to the track (do not care about competitive racing). 300whp, great suspension, great breaks, function over form, and something I can learn with. I drive it to work sometimes but mostly up in the mountains to relax.
    I mentioned the rear shock absorbers as it would be silly to lower the suspension without compensating for doing so.
    I was hoping there would be an option that did not involve 'hacking' the frame. I am cool with cutting and welding it as long as future function is not lost. Anything that woould not affect my eventual suspention goals (stated in my first post) I am all for.
  • i r teh noobz
    i r teh noobz
    • 1046
    #5
    I'll give you 100 bucks for the funky green springs. You can take my stockers and cut a few coils off to achieve moar low.
    I recall something about Mustang springs fitting the rear, but a 1" lowering spring was about stock height on the Z. I don't think there's any room to lower the rear spring mount, but maybe the body side could be cut and moved up? Its not used with a subframe swap, so I suppose messing it up wouldn't be a big deal.
    5.3 LSx Z31
