MORE RT stuff: Negative camber roll center adjusters!
  • frostvectron
    frostvectron
    • 1044
    #16
    300zxturboftw;340125 wrote: Should seat completely fine still with his design. +1 to adam saying wish he had these done a week or so ago!
    Cool! As long as it works, I don't care what the shape is. :P
    Can't wait to see the samples! You can put me down on the interested list.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • ShamWow
    ShamWow
    • 1905
    #17
    Benefit of half cup is that the coilover adjuster can extend out the bottom of the knuckle
    "produce first.talk second."
  • MADMIKE
    MADMIKE
    • 1533
    #18
    Great looking design. Subd
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • G-E
    G-E
    Junior Member
    • 6320
    #19
    Thanks
  • slammedcoupe
    slammedcoupe
    • 721
    #20
    Careless;340126 wrote: not sure if titty joke or you like adding unnecessary weight to corners of car/suspension.
    really how much weight are we talking? they aluminum or steel its likely less than half a pound by far…
    and I didn't realize it but it could have been a titty joke
  • Careless
    Careless
    • 13279
    #21
    slammedcoupe;340387 wrote: really how much weight are we talking? they aluminum or steel its likely less than half a pound by far…
    everything adds up!
    i like titties. the more weight on them, the better.
  • G-E
    G-E
    Junior Member
    • 6320
    #22
    I just assumed it was a titty joke, but now I'm sad it wasn't
  • G-E
    G-E
    Junior Member
    • 6320
    #23
    Just to add an addendum about weight, I will try to limit the addition of weight where possible, sometimes it's a simple matter of adding a limited amount of machining complexity, in order to save unnecessary material.. of course if it doubles the cost I may rethink the approach
    There's a lot of things that I will not make in aluminum, specifically for strength reasons, but in every other case, where the stress can be refined to structural areas or even converted to say compressive load, then aluminum becomes a great option
    Compare my BBK, a kit installed on one side, calipers, brackets, rotors and all the hardware, weighs the same as a single *EDIT* 370z track/G37s rotor
    The s13 coilover adapter will add a tiny bit of weight over using a stance sleeve adapter, since any s13 coilover will have additional weight in the form of a bracket, this is function vs weight a tradeoff, much like a roll cage… this is not a part that could be made in aluminum
  • Careless
    Careless
    • 13279
    #24
    G-E;340409 wrote: this is not a part that could be made in aluminum
    sez you! hmmmmph!
    mostbet mostbet mostbet.
  • adamvann3
    adamvann3
    • 4160
    #25
    G-E;340409 wrote: Just to add an addendum about weight, I will try to limit the addition of weight where possible, sometimes it's a simple matter of adding a limited amount of machining complexity, in order to save unnecessary material.. of course if it doubles the cost I may rethink the approach
    I like how you are providing reasoning for yourself and careless..... No one was really concerned about weight.
    There is maybe 1 or 2 people here that I would call competitive racer...... Like you mentioned above, saving some weight is nice, but not to the point your doubling machining costs.
    I mean we should be switching too drilled titanium hardware
    86na - BlueZ
    85t - Mr Tickles
  • slammedcoupe
    slammedcoupe
    • 721
    #26
    lock wire holes for mad space shuttling
  • adamvann3
    adamvann3
    • 4160
    #27
    Ill be interested in seeing the prototypes installed and seeing the alignment differences. Best of luck!
    86na - BlueZ
    85t - Mr Tickles
  • Careless
    Careless
    • 13279
    #28
    adamvann3;340451 wrote: I like how you are providing reasoning for yourself and careless..... No one was really concerned about weight.
    for someone who was whining, bitching, and probably crying about inqui-z-tor making backhanded comments about photoshopping pictures in order to make them look good, you really have a good way of sneaking in backhanded comments yourself....
    ..... NOT.
    saving weight is never a bad thing. this is something that G-E and I discussed off the boards and is one of the features that are an advantage to this product. the lack of uneccessary metal provides both weight savings and ability to access the coilover adjuster, as well as a place for any water or road shmoo to drain through if it leaks down the threads, ultimately saving them from corroding just a little bit more than they would normally. what do you do when you market a product? you list all its advantages. any weight savings that doesn't compromise price or integrity is FEATURE.
  • Rustspecs13
    Rustspecs13
    • 283
    #29
    Saving weight is not a bad thing. Correct.
    But how many people on this board (or really any one) do you think will notice if the only change in the car is one with this design, and this design lacking the extra machining to make it lighter. Im not even sure if I would be able to tell my self.
    Have you done any FEA testing on this design? What makes you think this is structurally ok? Ive never seen a roll center adjuster like this one. Obviously doesn't mean its bad, just no one has done it before. Id like to see that it doesn't make the design significantly weaker. Its an interesting idea for sure, but it should be proven to be safe and sound of course.
    ~Alex
    splatter fake blood on fubar'd quarter and roll out.
  • Careless
    Careless
    • 13279
    #30
    you guys make me lol.
    FEA testing.
