De-powered rack for drifting.
84Zed31Senior Member- 707
Alright, so I blew my power steering rack a year and a half ago during an event and I have another event coming up end of next month. I de-powered the rack and the steering felt.. a little better.. I am going to install the knuckles from mikeP soon, and I was wondering if its better to drift with another power rack or just keep this de-powered rack.
Im currently on 205 tires, and I know that some of you have no problems with wider and stickier tires than mine for autocross. This question probably has been answered before, but whoever has drifted with de-powered vs. powered, can you chime in?
"Let's play Battleship! There's enough Z's for that.."
My thread thingy: http://z31performance.com/showthread…ep-Zed-84Zed31 -
Also I couldnt get much negative camber with my Stances, I might get kouki control arms to add more negative, but is there any other way to get more than -1.5 degrees? Im shooting for around -2.25 degrees. Would raising the height a little allow for more negative?
BSRJIRONMANSenior Member- 303
I have drifted in a car without an operational power steering system, and I don't recommend it. Well, if you value the functionality of your hands/fingers, that is. Transitions and line adjustments were scary. When that wheel starts to spin, you don't want your hands anywhere near it, haha.
"…i think bov needs oil, its not closing fast enough so the car dies when you come off of boost…" -Automotive Genius -
So what youre saying is that I need gauntlets to drift. Lol.
millsapsSenior Member- 133
drifting without power steering is stupid. fingers and arms will be beat up and protentially broken. -
Mad Mike's Madbull RX7 runs a manual rack, and he does backwards entries. It all comes down to preference and practice.
ButterSenior Member- 1519
…and tire size, wheel offset, caster and camber, leverage of the steering linkage, knuckle ratio, rack ratio, weight over the front axle, and the course layout.
You try to drive USAIR in a Z31 with no power steering, and you will be sitting in the pits wondering why you can't do very well. I want to upgrade to the kouki one.
http://youtu.be/L-VtlKqrPbk?t=1m47s[/video]]sigpic -
http://www.redz31.net/pages/powersteering.html
Supposedly the pump is different in that it's driven by a ribbed belt instead of a v belt. Don't know about the rack
That link says that you can put a newer PS pump on an old motor, but not the other way around. I have an old style PS pump on my 88T motor (ribbed crank pulley) and it works fine....wut -
Yeah ive decided to order a rack (..and take my de-powered as a core..). Ill stick with the zenki pump for now.
Thanks for the advice guys, ill update my build thread soon.
