link2394 link2395 link2396 link2397 link2398 link2399 link2400 link2401 link2402 link2403 link2404 link2405 link2406 link2407 link2408 link2409 link2410 link2411 link2412 link2413 link2414 link2415 link2416 link2417 link2418 link2419 link2420 link2421 link2422 link2423 link2424 link2425 link2426 link2427 link2428 link2429 link2430 link2431 link2432 link2433 link2434 link2435 link2436 link2437 link2438 link2439 link2440 link2441 link2442 link2443 link2444 link2445 link2446 link2447 link2448 link2449 link2450 link2451 link2452 link2453 link2454 link2455 link2456 link2457 link2458 link2459 link2460 link2461 link2462 link2463 link2464 link2465 link2466 link2467 link2468 link2469 link2470 link2471 link2472 link2473 link2474 link2475 link2476 link2477 link2478 link2479 link2480 link2481 link2482 link2483 link2484 link2485 link2486 link2487 link2488 link2489 link2490 link2491 link2492 link2493 link2494 link2495 link2496 link2497 link2498 link2499 link2500 link2501 link2502 link2503 link2504 link2505 link2506 link2507 link2508 link2509 link2510 link2511 link2512 link2513 link2514 link2515 link2516 link2517 link2518 link2519 link2520 link2521 link2522 link2523 link2524 link2525 link2526
Mustang springs
  • SoberZ31
    SoberZ31
    Member
    • 39
    Mustang springs
    I know some people have used misc. spring combinations on their z31 including mustang rear springs. my question is would front 2000 mustang gt springs at a spring rate of 450 be too stiff for the back of a 1986 Z31 N/A. I have a pair off of my old mustang just laying around and I was thinking of cutting them to size for the rear.
  • jaqattack02
    jaqattack02
    • 1185
    I hate it when people say this, but I really feel like it's required here. Search noob!
    If you type Mustang Springs into the search, this is like the 4th result… http://z31performance.com/showthread…ustang+springs
    My 1986 Turbo Build
  • frostvectron
    frostvectron
    • 1044
    What are you running for front springs?
    450 is pretty stiff. If your fronts are nowhere near as stiff your car will feel wonky in cornering because of the drastic imbalance. Really stiff rear and not so stiff front means the car will be easy to oversteer and not be so stable in hard cornering. What kind of shocks/struts are you running as well? 450 in the rear would require some beefy dampers.
    450 lb/in = 8 kg/mm. As comparison, powertrix coilovers are 9kg/mm front and 7kg/mm rear.
    I used to run 250 lb/in Mustang Mach 1 springs in the rear with ST springs in the front (see 3rd page of that thread and/or my build thread).
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • SoberZ31
    SoberZ31
    Member
    • 39
    yea I haven't done any suspension work yet I just have the springs laying around. and the aftermarket springs that are offered for our cars are too soft for my liking. I'm just trying to plan my suspension build on a decent budget. any suggestions would be great.
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #5
    yep. there was a great write up suggested in the 2nd post here…
    sigpic
  • SoberZ31
    SoberZ31
    Member
    • 39
    #6
    on the link I was given?
  • SoberZ31
    SoberZ31
    Member
    • 39
    #7
    I see everything about rear slings and shocks and that you can even use the rear shocks from a fox body, but not really much about front set up with the mustang springs in the rear
  • Careless
    Careless
    • 13279
    #8
    SoberZ31;342630 wrote: I see everything about rear slings and shocks and that you can even use the rear shocks from a fox body, but not really much about front set up with the mustang springs in the rear
    not sure what you're asking here??? the springs do not work in the front, and you asked only about the rear in your first post…
    that thread which was linked came to a pretty solid conclusion; the front or rear mustang springs in the rear of the z31 will work, with some cutting to achieve desired heights, and droop limiters on stiffer springs at low height to prevent them from possibly falling out.
  • SoberZ31
    SoberZ31
    Member
    • 39
    #9
    yes I understand that. my next question is what spring set up would you suggest pairing in the front of the Z since the mustang springs will only work in the back and most aftermarket springs aren't that stiff
  • jaqattack02
    jaqattack02
    • 1185
    #10
    SoberZ31;342637 wrote: yes I understand that. my next question is what spring set up would you suggest pairing in the front of the Z since the mustang springs will only work in the back and most aftermarket springs aren't that stiff
    Have you read the link that was posted yet? From that thread…
    Axel kain;283715 wrote: Anyway.......
    With the tokicos up front and the rear "c" springs in the rear,
    it has good balance going over bumps. The car sits level, all around better than the cut tokico rears. I also have the blues all around so damping is appropriate.
    Haven't launched it yet, but all things considered. Should squat a bit but nothing to bawk about. Took an entrance ramp very spiritedly, and that experience told me I need thicker sways, and LSD. Otherwise the 245 rear tires will be my next traction loss cause.
    My 1986 Turbo Build
  • SoberZ31
    SoberZ31
    Member
    • 39
    #11
    yea i did read that sorry for the confusion. is there anything stiffer then the tokico springs though. dont care much for a loose feeling car and the spring rates on them arent the best.
  • jaqattack02
    jaqattack02
    • 1185
    #12
    Again, read the thread…
    michaelp;283554 wrote: Z31 springs:
    NA: 136lb front, 140lb rear
    AE: 146lb front, 188lb rear
    86T: 146lb front, 188lb rear
    87-89T: 196lb front, 188lb rear
    Shiro: 207lb front, 224lb rear
    STs: 200lb front, 226lb rear
    Tokicos: 150lb front, 165lb rear
    Z3Rs: 300lb front, 315lb rear
    My 1986 Turbo Build
  • SoberZ31
    SoberZ31
    Member
    • 39
    #13
    I did and that's why I asked if there are any other stiffer spring options for the front
  • jaqattack02
    jaqattack02
    • 1185
    #14
    SoberZ31;342654 wrote: I did and that's why I asked if there are any other stiffer spring options for the front
    What is in that list is what's available. The only thing missing is the Eibach springs. I'm not sure of the rate on those, but I think they are on the softer side.
    The only stiffer option would be coilovers. But if you were going to spend the $$ on coils you wouldn't be trying to be cheap by using a set of Mustang springs you have sitting around.
    My 1986 Turbo Build
  • SoberZ31
    SoberZ31
    Member
    • 39
    #15
    well I just experiment with things then since it seems you are one of those "forum" guys everyone. sorry to pollute the forum, not my intention.
