link2660 link2661 link2662 link2663 link2664 link2665 link2666 link2667 link2668 link2669 link2670 link2671 link2672 link2673 link2674 link2675 link2676 link2677 link2678 link2679 link2680 link2681 link2682 link2683 link2684 link2685 link2686 link2687 link2688 link2689 link2690 link2691 link2692 link2693 link2694 link2695 link2696 link2697 link2698 link2699 link2700 link2701 link2702 link2703 link2704 link2705 link2706 link2707 link2708 link2709 link2710 link2711 link2712 link2713 link2714 link2715 link2716 link2717 link2718 link2719 link2720 link2721 link2722 link2723 link2724 link2725 link2726 link2727 link2728 link2729 link2730 link2731 link2732 link2733 link2734 link2735 link2736 link2737 link2738 link2739 link2740 link2741 link2742 link2743 link2744 link2745 link2746 link2747 link2748 link2749 link2750 link2751 link2752 link2753 link2754 link2755 link2756 link2757 link2758 link2759 link2760 link2761 link2762 link2763 link2764 link2765 link2766 link2767 link2768 link2769 link2770 link2771 link2772 link2773 link2774 link2775 link2776 link2777 link2778 link2779 link2780 link2781 link2782 link2783 link2784 link2785 link2786 link2787 link2788 link2789 link2790 link2791 link2792
Strut Tubes
  • Big Slappy Z
    Big Slappy Z
    • 237
    Strut Tubes
    I have a question about strut tube compatibility. I just removed my front strut assembly to redo the ball joints and upper strut mount because I have a very loud and annoying clicking noise that happens each time my car hits a bump. I pulled off the spring and I find that the front strut has an awful lot of play in the strut tube. If I move it up and down there is about 1/8" of play. I feel like this is the culprit, as if the owner before me installed the wrong struts in the tubes. I believe the car was originally a turbo model, and maybe the struts were to fit an NA, nonadjustable shock? Is it supposed to be like this, or should it be snug in there?
    Could I add some shims in there to fix it? WTF this kind of pisses me off
  • G-E
    G-E
    Junior Member
    • 6320
    Take off the spindle from the steering knuckle, remove the hat/spring hardware, remove the gland nut, pull out the strut, compare the inner diameter of the tube to the outer diameter of the strut insert.. gasp in disbelief, throw tools around in anger, come back to z31p to report
  • Big Slappy Z
    Big Slappy Z
    • 237
    Thanks for the recount on my last 4 hours lol. Looks like the strut cartridge matches, I added some oil to the tube and dropped it in so it was a little more stable in there, and I just added 2 neoprene rubber washers right above the strut cartidge above the metal washer and it's all good....at least I think. I'll report on whether or not the sound stops when I get the front end all back up.
    And then more bad news:
    I go to put on the new top strut mount and all of the studs fall out. None of them will grab on the hole they are in so trying to mount the strut means the three nuts on top keep spinning. Awesome. How do companies get away with sending out bullshit products like this? I wanna throw that masterpro garbage through oreilly's window
  • G-E
    G-E
    Junior Member
    • 6320
    When I installed my koni inserts, there's gland nuts provided for both turbo and non-turbo tubes, but the insert itself had a nub on the bottom you have to trim down to the height you need, even in the instructions it says measure and hacksaw accordingly…
    The koni struts were designed to fit the non-turbo tube fairly snug, I imagine seating in turbo strut tubes would be a little more annoying
    Are your "masterpro" strut mounts the same design as the factory z31 parts? can you swap the old ones in?
  • Big Slappy Z
    Big Slappy Z
    • 237
    #5
    I looked at that after I gave up trying to get them to seat correctly. The studs aren't splined like you would think they should be, they have three small ticks that are supposed to seat the stud. Turns out the factory part is the same way, although the mount itself is probably more precisely cut (and the studs too).
    I'll probably just end up swapping in the old strut mount and return the new one (but keep the new bearing, they won't be able to tell the difference ha)
    Although it kind of kills me seeing one of the strut towers look asymmetrically newer than the other, but whatever. We'll see how this works out
  • G-E
    G-E
    Junior Member
    • 6320
    #6
    Nothing some alprazolam can't fix hahah
  • i r teh noobz
    i r teh noobz
    • 1046
    #7
    My strut mount studs fall out as well. Its really annoying. I've contemplated gluing the studs in place.
    5.3 LSx Z31
  • Big Slappy Z
    Big Slappy Z
    • 237
    #8
    Tried it with super glue. Did not work out....
    next step, super glue + red loctite? lol
  • G-E
    G-E
    Junior Member
    • 6320
    #9
    Bubblegum and ducktape?
  • visco
    visco
    Member
    • 63
    #10
    Had the same issue with new mounts and the studs not staying in place. If you can get the nut started on the threads, you should be able to grap the top of the stud and hold it while you tighten the nut onto the body. Worked for me. I cant remember exactly how I did it without messing up the threads (pliers/wrench), been in place for 6 months. torque it and it wont move. The difficult part was getting the mount studs through the body without them falling out. that's where I used JB weld to tack them in place so I could pass them through the body mount holes. fun fun
  • i r teh noobz
    i r teh noobz
    • 1046
    #11
    If you have an impact you can just zap them a few times after you get the nuts started. No damage to the threads that way. They will still fall out later if you ever have to loosen the nuts.
    JB Kwik will be my glue of choice when I have to pull my strut bar agan. Sets up in 4 minutes and cures in a few hours.
    My mounts are also MasterPro brand.
    5.3 LSx Z31
  • Big Slappy Z
    Big Slappy Z
    • 237
    #12
    I first tried to screw the nuts down so torquing them would grab the studs into place, but I couldn't get them to the bottom without having it spin. I didn't want to mess up the threads so I tried grabbing the bottom, gluing, doing everything to no avail. I ended up returning it and getting my money back. I kept the new bearing and gave them the old one though. =D
