link3192 link3193 link3194 link3195 link3196 link3197 link3198 link3199 link3200 link3201 link3202 link3203 link3204 link3205 link3206 link3207 link3208 link3209 link3210 link3211 link3212 link3213 link3214 link3215 link3216 link3217 link3218 link3219 link3220 link3221 link3222 link3223 link3224 link3225 link3226 link3227 link3228 link3229 link3230 link3231 link3232 link3233 link3234 link3235 link3236 link3237 link3238 link3239 link3240 link3241 link3242 link3243 link3244 link3245 link3246 link3247 link3248 link3249 link3250 link3251 link3252 link3253 link3254 link3255 link3256 link3257 link3258 link3259 link3260 link3261 link3262 link3263 link3264 link3265 link3266 link3267 link3268 link3269 link3270 link3271 link3272 link3273 link3274 link3275 link3276 link3277 link3278 link3279 link3280 link3281 link3282 link3283 link3284 link3285 link3286 link3287 link3288 link3289 link3290 link3291 link3292 link3293 link3294 link3295 link3296 link3297 link3298 link3299 link3300 link3301 link3302 link3303 link3304 link3305 link3306 link3307 link3308 link3309 link3310 link3311 link3312 link3313 link3314 link3315 link3316 link3317 link3318 link3319 link3320 link3321 link3322 link3323 link3324
Rear lower control arm bolts
  • Modelli
    Modelli
    Member
    • 69
    So i was reading that these have a tendency to break or get seized. As i'm starting to redoing the entire rear suspension, i ordered new bolts/nuts/washers and bushings (for the metal guide needed to install the urethane ones). When i was looking up the part numbers it listed 2 seperate part numbers for the bolts. Is one bolt a standard bolt and the other the eccentric/cam bolt? or are they both cam bolts? This is what i received today, i only ordered 2 of the bolts, because i wanted to confirm i was getting the right ones.
    Now do I need to order another 2 just like these, or is there a different bolt that i need to order?
  • G-E
    G-E
    Junior Member
    • 6320
    Only 2 of the 4 are supposed to be cam bolts, so the sleeves match the bolts
  • Modelli
    Modelli
    Member
    • 69
    so are the other 2 just standard bolts? Do all the bolts have issues freezing up or just the cam bolts?
  • 862sik
    862sik
    • 2159
    Modelli;343560 wrote: so are the other 2 just standard bolts? Do all the bolts have issues freezing up or just the cam bolts?
    I think its just the cam one, always the passenger side lol. Put anti seiz in that sucker.
    My Build Thread
  • i r teh noobz
    i r teh noobz
    • 1046
    #5
    Only the cam bolts seem to stick. Not sure why. They do that on everything, not just Nissans. 50% of the alignments I get at work can't be done right because the rear toe adjusters are rusted solid, even on cars as new as 2009.
    5.3 LSx Z31
  • Modelli
    Modelli
    Member
    • 69
    #6
    probably because of the gap the cam bolt creates, allows more dirt/water inside. I didn't have issues with many cam bolts at work, but for the stubborn ones i have an 8lb mini sledge that normally made them cooperate. Only on the older nissan trucks were they a pita.
  • Modelli
    Modelli
    Member
    • 69
    #7
    Anyone have the p#s for the eccentric bushings, when I look them up it keeps referencing me to the bushings I already have(non eccentric).
  • PrideZ31
    PrideZ31
    • 328
    #8
    About to do the rear control arm bushings myself. My camber is eating my tires, and I'm hoping the new bushings will keep them tight.
    __________________________________________________ ___________________
    "Aim towards the Enemy." --
    Instruction printed on US Rocket Launcher
    86 N/A:Rebuilt Autotragic, Cat Delete, PRW-2, Poly Bushings, MSA sway bars, Pioneer HU and Speakers, Sleepy Eyes
    Current 0-60: 10.0 flat =[
  • adamvann3
    adamvann3
    • 4160
    #9
    Modelli;347714 wrote: Anyone have the p#s for the eccentric bushings, when I look them up it keeps referencing me to the bushings I already have(non eccentric).
    All the bushing are non-eccentric. The entire control arm moves with the eccentric hardware, not the bushing.
    86na - BlueZ
    85t - Mr Tickles
