Rear subframe
spalding87z31Junior Member- 12
Rear subframe
I'm in the process of replacing all the old rubber in the rear with poly do I need new collars for the rear subframe bushings?Attached Files- 2014-04-12_11-37-39_867.jpg (98.3 KB)
What do your eyes tell you…are they in bad shape?Cha iro
they are bad, was hopeing that i wouldnt need them with the poly bushing but looks like i need to buy oem bushing and get the metal off the rubber. -
reddzxSenior Citizen- 6440
I think the new sub-frame bushing come with a collar
1991 Hard-body 2WD
my prothane lower control arms came with a sleeve for the outer bushings, not the serrated edged ones for the inner bushings. those need to be saved or pillaged. -
ok i order the subframe bushing the other day i should be good then, hopefully get it all back together this week after i sand blast and paint the subframe. Thanks for the info.
