link3458 link3459 link3460 link3461 link3462 link3463 link3464 link3465 link3466 link3467 link3468 link3469 link3470 link3471 link3472 link3473 link3474 link3475 link3476 link3477 link3478 link3479 link3480 link3481 link3482 link3483 link3484 link3485 link3486 link3487 link3488 link3489 link3490 link3491 link3492 link3493 link3494 link3495 link3496 link3497 link3498 link3499 link3500 link3501 link3502 link3503 link3504 link3505 link3506 link3507 link3508 link3509 link3510 link3511 link3512 link3513 link3514 link3515 link3516 link3517 link3518 link3519 link3520 link3521 link3522 link3523 link3524 link3525 link3526 link3527 link3528 link3529 link3530 link3531 link3532 link3533 link3534 link3535 link3536 link3537 link3538 link3539 link3540 link3541 link3542 link3543 link3544 link3545 link3546 link3547 link3548 link3549 link3550 link3551 link3552 link3553 link3554 link3555 link3556 link3557 link3558 link3559 link3560 link3561 link3562 link3563 link3564 link3565 link3566 link3567 link3568 link3569 link3570 link3571 link3572 link3573 link3574 link3575 link3576 link3577 link3578 link3579 link3580 link3581 link3582 link3583 link3584 link3585 link3586 link3587 link3588 link3589 link3590
Asco solid sibframe bushings
  • ToiletFlush
    ToiletFlush
    Junior Member
    • 25
    Was wondering if anyone had tried these before and how they were suppose to fit in the subframe. Mine are loose enough on the subframe that im able to still take them in and out by had. Just wanted to know if its suppose to be like that.
  • Kutakino
    Kutakino
    • 585
    Mine were the same way, as far as I can tell I have had no problems from them. They greatly improved the feeling of the rear end.
    86T GLL
  • nismopu
    nismopu
    Administrator
    • 2221
    They Were made to retain the sleeves from the old bushings but the next run wont be that way. I installed à set recently on my car without the sleeves and drive the car fairly hard with no Ill effects. It improved the tired rear suspension à ton and makes the car more enjoyable under acceleration.
  • ToiletFlush
    ToiletFlush
    Junior Member
    • 25
    Awesome! Yeah I keep my sleeves in and it seems like they go in there snug but not tight enough to were I can't take them out anymore , glad to hear this is normal. What about noise ? Did you guys get any noise coming from the bushings ?
