link3724 link3725 link3726 link3727 link3728 link3729 link3730 link3731 link3732 link3733 link3734 link3735 link3736 link3737 link3738 link3739 link3740 link3741 link3742 link3743 link3744 link3745 link3746 link3747 link3748 link3749 link3750 link3751 link3752 link3753 link3754 link3755 link3756 link3757 link3758 link3759 link3760 link3761 link3762 link3763 link3764 link3765 link3766 link3767 link3768 link3769 link3770 link3771 link3772 link3773 link3774 link3775 link3776 link3777 link3778 link3779 link3780 link3781 link3782 link3783 link3784 link3785 link3786 link3787 link3788 link3789 link3790 link3791 link3792 link3793 link3794 link3795 link3796 link3797 link3798 link3799 link3800 link3801 link3802 link3803 link3804 link3805 link3806 link3807 link3808 link3809 link3810 link3811 link3812 link3813 link3814 link3815 link3816 link3817 link3818 link3819 link3820 link3821 link3822 link3823 link3824 link3825 link3826 link3827 link3828 link3829 link3830 link3831 link3832 link3833 link3834 link3835 link3836 link3837 link3838 link3839 link3840 link3841 link3842 link3843 link3844 link3845 link3846 link3847 link3848 link3849 link3850 link3851 link3852 link3853 link3854 link3855 link3856
87-89 Hubs for z32 brakes, curious question.
  • ZMIKEMAN
    ZMIKEMAN
    Member
    • 79
    Just had a quick thought, might be stupid but I thought I'd throw it out there. What exactly is the need for 87-89 turbo hubs on earlier models for the z32 brake upgrade. Its got to be more then just for the 5 lug right? If it was just that then I could go ahead and switch my AE over without changing the hubs. I have access to my dads z32 leftover pile for those misc parts from which I have Z32 rotors and pads, I just need the lines and calipers but wanted to see if I could get away without the hubs (Prob not, but its worth the questioning)? I have access to my dads z32 leftover pile for those misc parts, lol.
  • G-E
    G-E
    Junior Member
    • 6320
    it has longer studs? I didn't measure the offset but if it's different it isn't much, assuming all 87+ have the same offset that would mean around 1cm
  • ImaZPA
    ImaZPA
    Member
    • 41
    87-89 T hubs have slip on rotors, earlier 5 lugs have bolt on rotors, you need the later hubs to match up rotors w/calipers
    Those who are willing to settle for less than the best quite often get it
  • khyronzx
    khyronzx
    • 1204
    it will work work on the old style rotors & hubs(see brake upgrade thread) however there isn't much of a point in doing it as the old rotors aren't very big, the only gains you will get is from the additional clamping force, and it the smaller rotor will cause funky pad an rotor wear porblems, but it will work.
    "Beer is proof that god wants us to be happy" - Benjamin Franklin
  • G-E
    G-E
    Junior Member
    • 6320
    #5
    theres no reason the older style hubs can't use slip on rotors besides stud length, which can be replaced
  • khyronzx
    khyronzx
    • 1204
    #6
    you know, i kinda had that thought as well, but will the hat clear the tabs that the old rotor bolts to on the hub?
  • simply86T
    simply86T
    • 413
    #7
    G-E wrote: theres no reason the older style hubs can't use slip on rotors besides stud length, which can be replaced
    I really hope someone here has the resources to try that out. 87-89 turbo hubs are not cheap, and they are hard to come by.
    Matte Black 86T - Sold
  • G-E
    G-E
    Junior Member
    • 6320
    #8
    the only issue is fitment depending on the rotor, the hub diameter is slightly different between bolt up and slip on.... so the rotor needs to have a larger hat or rear opening.... or the bolt up hub can be trimmed on a lathe, the amount needing to be shaved is like 4mm or something (for the stock rotor)
