link4123 link4124 link4125 link4126 link4127 link4128 link4129 link4130 link4131 link4132 link4133 link4134 link4135 link4136 link4137 link4138 link4139 link4140 link4141 link4142 link4143 link4144 link4145 link4146 link4147 link4148 link4149 link4150 link4151 link4152 link4153 link4154 link4155 link4156 link4157 link4158 link4159 link4160 link4161 link4162 link4163 link4164 link4165 link4166 link4167 link4168 link4169 link4170 link4171 link4172 link4173 link4174 link4175 link4176 link4177 link4178 link4179 link4180 link4181 link4182 link4183 link4184 link4185 link4186 link4187 link4188 link4189 link4190 link4191 link4192 link4193 link4194 link4195 link4196 link4197 link4198 link4199 link4200 link4201 link4202 link4203 link4204 link4205 link4206 link4207 link4208 link4209 link4210 link4211 link4212 link4213 link4214 link4215 link4216 link4217 link4218 link4219 link4220 link4221 link4222 link4223 link4224 link4225 link4226 link4227 link4228 link4229 link4230 link4231 link4232 link4233 link4234 link4235 link4236 link4237 link4238 link4239 link4240
Possible to use 1 N/A Strut housing and 1 T housing?
  • mwaker
    mwaker
    Junior Member
    • 9
    I have a 86T and fried my Passenger side spindle. I have a new wheel hub and bearings, but I am having a hard time finding a T strut housing (because the spindle and the strut tubing are one piece). If I installed a N/A strut housing would it work?
    My shocks are KYB so they should fit the N/A (cause I had to use the converter kit) and I have Eibach springs currently on the vehicle
    Ideas?
  • shromy
    shromy
    • 2189
    It would if you used one from a car up to 4/87
    Hmmm, Whats next?
    84ZXT
  • mwaker
    mwaker
    Junior Member
    • 9
    Would the rotor, hub, caliper, wheel barrings from the T transfer OK to the N/A strut/spindle?
    I'd assume there would really be no difference in ride height, or performance…
  • G-E
    G-E
    Junior Member
    • 6320
    The hub is interchangeable between spindles (aka strut tube with kingpin) all years, as are the brakes assuming they are matched with the respective hubs
    The spindles vary across the years, the kingpin angle is different for 84-85, the tube width varies turbo and non-turbo (ss is same as non-turbo), and wall thickness varies pre-88 and 88+
    The simplest thing do do is get both spindles in a set from a chuki/kouki to match your car, if both happen to be turbo, use the turbo gland nuts with your strut inserts or vice versa if they fit non-turbo and you have those gland nuts
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #5
    4/87 has nothing to do with the strut tubes or suspension.
    1991 Hard-body 2WD
  • i r teh noobz
    i r teh noobz
    • 1046
    #6
    If funds allow, perhaps this is a good time to go coilover?
    5.3 LSx Z31
  • mwaker
    mwaker
    Junior Member
    • 9
    #7
    Funds don't allow for coilovers yet. Even if I did had funds, I'd still need to find a new spindle to weld the coilovers to.
    @Reddzx - would the strut tubes and spindle from an 87 work? I know they changed the design of the cars between 86 and 87…don't know about the spindles..
  • NuCOTech
    NuCOTech
    Member
    • 76
    #8
    From what I was told. The spindles have different kingpin angles and you would not get the same handling and you would have alignment issues. You would want to stick with 84-86 or 87-89 spindles. Remember, they are designed to work with their respective control arms which aren't the same length.
  • jaqattack02
    jaqattack02
    • 1185
    #9
    If you have an 86, you need them from an 84-86 car. 87-89 is different.
    My 1986 Turbo Build
  • mwaker
    mwaker
    Junior Member
    • 9
    #10
    Ok - what I've determined from this discussion is to find an 84-86 strut assembly - if turbo great, if N/A need to have gland nut
  • G-E
    G-E
    Junior Member
    • 6320
    #11
    84-85 then… 86 was widebody… and I would assume 50th ae versions are also like 86's
  • michaelp
    michaelp
    • 9384
    #12
    G-E;346686 wrote: 84-85 then… 86 was widebody… and I would assume 50th ae versions are also like 86's
    Theres no difference in 84-86 strut tubes except NA vs turbo. Same Nissan PNs, same compared side to side. The track difference with widebody vs narrowbody was made up with wheel offset changes.
  • michaelp
    michaelp
    • 9384
    #13
    And as far as putting 87-89 spindles on a early car, it'll merely make the track very mildly wider. It won't affect alignment in any way.
