link0 link1 link2 link3 link4 link5 link6 link7 link8 link9 link10 link11 link12 link13 link14 link15 link16 link17 link18 link19 link20 link21 link22 link23 link24 link25 link26 link27 link28 link29 link30 link31 link32 link33 link34 link35 link36 link37 link38 link39 link40 link41 link42 link43 link44 link45 link46 link47 link48 link49 link50 link51 link52 link53 link54 link55 link56 link57 link58 link59 link60 link61 link62 link63 link64 link65 link66 link67 link68 link69 link70 link71 link72 link73 link74 link75 link76 link77 link78 link79 link80 link81 link82 link83 link84 link85 link86 link87 link88 link89 link90 link91 link92 link93 link94 link95 link96 link97 link98 link99 link100 link101 link102 link103 link104 link105 link106 link107 link108 link109 link110 link111 link112 link113 link114 link115 link116 link117 link118 link119 link120 link121 link122 link123 link124 link125 link126 link127 link128 link129 link130 link131 link132
Cali wheel options after front coilover upgrade
  • Pauls
    Pauls
    Member
    • 64
    Hey,
    Just upgraded to stance coilovers all round on my 89 z31 cali.
    Front uses strut tubes and knock adaptor.
    Issue I have is pre-upgrade I was able to fit;
    18x8 35+ (lenso dc6) & 18x7.5 30+ (350z touring)
    After the upgrade need 15mm spacers &
    18x8 35+ inner wheel touches coilover
    18x7.5 30+ clears by just under 5mm.
    Quite disappointed that I needed to go spacers and even more so that only 350z wheels fit.
    Running standard LCA's.
    Would love others feedback as to whether;
    1. they faced same challenges
    2. what width wheels and offsets they have gone with
    3. spacers or without spacers and width?
    Thanks..
    Love z31's as much as I do? Check out my build: http://www.zdriver.com.au/index.php/…__80#entry2219
  • G-E
    G-E
    Junior Member
    • 6320
    That's normal, a coilover is typically much wider diameter than a coil on strut setup, and there are no protruding parts like perches below the wheel edge
  • quicksilverz31
    quicksilverz31
    Member
    • 83
    Like GE said, it's normal to have less inner clearance on the front after switching to coilovers. That being said, you should consider running wheels with a more aggressive offset. 18x8 +35 and 18x7.5 +30 is weaksauce on Z31's. As far as wheel sizing goes, I'm running a 16x8 +0 and it's not even that aggressive. My tires are what get me closer to flush. Depending on where my new tire size will put me I may end up running 10-15mm spacers.
    87 300ZX: VG33ET, 30a, Bilsteins/Eibachs, Stance tension rods, MSA sway bars, Cusco strut braces, ASCO Camber plates, RCA's and motor mounts, poly everything else.
  • Pauls
    Pauls
    Member
    • 64
    Rear upgrade worked out well with no spacers, so I would prefer no spacers on the front. Need to now get my head around widths and offset combinations that will work for the front and then see what I can source that doesn't cost an arm and a leg.
  • Ven
    Ven
    • 510
    #5
    quicksilverz31;346448 wrote: 18x8 +35 and 18x7.5 +30 is weaksauce on Z31's..
    /thread lol
  • quicksilverz31
    quicksilverz31
    Member
    • 83
    #6
    Ven;346463 wrote: /thread lol
    +1
    There's nothing wrong with using spacers or adapters to get a better fit on wheels you already have. But if you're looking to get some different wheels take a measurement of where your wheels sit now and where you want them to.
    Use either of these websites to figure out the differences in fitment for wheels with different widths/offsets.
    http://www.1010tires.com/Tools/Wheel-Offset-Calculator
    http://www.willtheyfit.com/
  • Pauls
    Pauls
    Member
    • 64
    #7
    Wheel spacers are illegal for street use in Australia.
    They are also quite strict on ride height, wheel clearances etc.
    When it comes to car mods, Compared to some of the American builds I have seen, you can't fart in Australia without being busted.
    Thats one of the reasons I want my build for those who don't know z31s to think its original.
    So weaksauce at times can be your friend… officer
  • adamvann3
    adamvann3
    • 4160
    #8
    Fill out your profile, that would help.
    Like mentioned above the OEM struts have the spring perch above the wheel, so the stock strut housing was the only thing the wheel and tire needed to clear. Now with coilovers, the damper body increased in diameter and depending on springs the wheel will now need to clear the spring perch and spring.
    From your picture you need to clear the spring OD:
    (Spring Outer Diameter - Strut Tube Diameter) / 2 = the difference in offset needed to clear
    The difference being = to your previous setup and it will also bring the wheel out closer to the fender by that amount
    Or learn from what others have ran. 17x9 -3 running 235/40 tires cleared my spring perches by finger width. Good rule of thumb it 9in wide wheels at zero offset. This will provide inner clearance, while needing to do close to nothing to your front fenders (at -2 degrees of camber).
    86na - BlueZ
    85t - Mr Tickles
  • michaelp
    michaelp
    • 9384
    #9
    +30 is a lame offset, thats more sunken than stock for a 7.5" wide wheel. I have 16x8, -10s…they clear fine. You need RWD wheels not FWD wheels.
  • Greasedmonkey
    Greasedmonkey
    • 516
    #10
    the wheels I just put on have a +30 offset on a 7.5 in wheel. They are rwd wheels. I also have a 25mm spacer too.
  • michaelp
    michaelp
    • 9384
    #11
    Greasedmonkey;346805 wrote: the wheels I just put on have a +30 offset on a 7.5 in wheel. They are rwd wheels. I also have a 25mm spacer too.
    350Z/G35 don't qualify as RWD wheels. Those things have FWD offsets. lol
  • Pauls
    Pauls
    Member
    • 64
    #12
    michaelp;346631 wrote: +30 is a lame offset, thats more sunken than stock for a 7.5" wide wheel. I have 16x8, -10s…they clear fine. You need RWD wheels not FWD wheels.
    8" with 10 or 15 offset would be ideal as would eliminate need for spacers, however dont like my luck finding 18's in that size let-alone at a good price.
    Looking online this week and havent found anything..
  • DeleriousZ
    DeleriousZ
    • 6874
    #13
    forget the 8" and go for a 9/10 or 9.5/10.5 split. They're more common (read xxr, rota, other inexpensive replica wheels) and can be had for a pretty decent price. Check zilvia.net's wheel and tire for sale section. It's extremely active and can find some decent deals on there if you're fast about it.
    1990 jetta vr6'd
