link1596 link1597 link1598 link1599 link1600 link1601 link1602 link1603 link1604 link1605 link1606 link1607 link1608 link1609 link1610 link1611 link1612 link1613 link1614 link1615 link1616 link1617 link1618 link1619 link1620 link1621 link1622 link1623 link1624 link1625 link1626 link1627 link1628 link1629 link1630 link1631 link1632 link1633 link1634 link1635 link1636 link1637 link1638 link1639 link1640 link1641 link1642 link1643 link1644 link1645 link1646 link1647 link1648 link1649 link1650 link1651 link1652 link1653 link1654 link1655 link1656 link1657 link1658 link1659 link1660 link1661 link1662 link1663 link1664 link1665 link1666 link1667 link1668 link1669 link1670 link1671 link1672 link1673 link1674 link1675 link1676 link1677 link1678 link1679 link1680 link1681 link1682 link1683 link1684 link1685 link1686 link1687 link1688 link1689 link1690 link1691 link1692 link1693 link1694 link1695 link1696 link1697 link1698 link1699 link1700 link1701 link1702 link1703 link1704 link1705 link1706 link1707 link1708 link1709 link1710 link1711 link1712 link1713 link1714 link1715 link1716 link1717 link1718 link1719 link1720 link1721 link1722 link1723 link1724 link1725 link1726 link1727 link1728
Lots of new stuff installed today but.....
  • smeagol
    smeagol
    Member
    • 43
    okay so i took my car into my buddys shop and we found the r/r wheel bearing is soo damn loose lol and that the diff is leaking at the axle seal just pouring grease. so we are replacing the bearings/arm and seals. Ripping my seats and carpet up and wielding sheets over the holes that the leaking t-tops caused. replacing my l/f caliper (leaking) front bearings and r/f spindle and a valve cover gasket all for $1200. sounded like a good deal so i went with it ya?
    But the big thing he did not talk about was the l/f lower control arm how it is ovaled out at the subframe and it shifts and causes the car to pull like a bitch to the left when it does camber out. He said he did not see anything but i clipped a gopro cam and watched it shift when i brake hard or turn left. he said he is gonna take another look but if so he will replace it with poly bushings. He said my pull was from my rear bearings being shot ass fuh. Opinons?
    Do any of you know where i can get some aftermarket ball joints, bushings and links and control arms for z31's?
  • adamvann3
    adamvann3
    • 4160
    First, your grammar is horrible and everything requires a lot of concentration to read.
    Find some used front LCAs to replace your current "ovaled" set (I would love to see a picture of them once they are off, I cannot see how these would bend in that area). You get some battle version universal adjustable endlinks and weld them on. Or most places that sell truck offroading suspension have similar universal weldable options. Personally, poly bushings have never failed me on the LCAs.
    You can pick up ball joints from anywhere. They are plentiful and abundant. No need to go with anything crazy as the steering knuckle is separate from the LCA so it doesnt need to be extended or messed with.
    86na - BlueZ
    85t - Mr Tickles
  • G-E
    G-E
    Junior Member
    • 6320
    It's a safe bet that all your bushings are toast, the subframe bushings in the back are notorious for causing steering problems under load, your front control arm bushings are almost certainly bad
  • Gregmatic
    Gregmatic
    • 2193
    I've got a set of control arms with brand new balljoints installed, bushings are perfect. They are early style as they don't have the larger tension rod holes from the 88/89, so they are compatible with 84-87. PM for a price if interested…reasonable
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #5
    you are VERY likely going to need to either replace the subframe, or repair the control arm's bolt holes! same thing happened on my 87T. youre also likely to need to cut bolts out, so be prepared to replace them all. esp. the rear eccentrics!
    the rear control arm bearings can be easily sourced, and aren't terrible to replace.
    sigpic
  • Gesler300
    Gesler300
    Junior Member
    • 23
    #6
    If the mounting holes in the subframe are ovaled you can weld a washer to the subframe had to do that to mine 4-5 years ago and still no problem.
  • smeagol
    smeagol
    Member
    • 43
    #7
    i sent you a pm greg. I am going to but a master poly bushing kit from thezstore.com and just replace every bushing as a good start. The master kit does not come with subframe bushings so ill buy them separately. I will see when i replace them if the hole are ovaled out at the subframe and wield some heavy duty washers on or if its just the bushings. Thanks for the tips guys you have pointed out several things i should just replace.
