Coil Over Suspenssion: Who makes it and a direct fit
LA zSenior Member- 103
OK, I'm going with coilovers. Who makes the direct fit, no BS stuff. Recommendations? -
reddzxSenior Citizen- 6440
Stance and Powertrix are bolt on
1991 Hard-body 2WD
wasupman2Senior Member- 248
Aren't they almost bolt on? Because you gotta weld the front hubs.Originally posted by reddzxStance and Powertrix are bolt on'85 z31 stock -
Yes, you have to weld the front strut tubes with the adapters.Originally posted by wasupman2Aren't they almost bolt on? Because you gotta weld the front hubs.Usual Z31 suspect: Garage Queen (aka broken)
Both stance and powertrix do.
If that's too much work… coilovers aren't for you! -
Showaski39Senior Member- 148
No one sells a 100% bolt-on coilovers for the Z31. Powertrix and Stance are the only ones that sell almost bolt on coilovers. The rears are 100% bolt-on while the fronts requires you to cut and weld your stock strut tubes to the new coilovers.
If you send Stance or Powertrix a pair of front Z31 knuckles/hubs, they can weld them onto the front coilovers for you and then ship a set of coilovers back to you that WILL BE 100% bolt-on when you receive it.
Powertrix will be starting a group buy soon if you are truly in the market for good coilovers, and want to support a local business as their based out of San Diego, CA.
Powertrix's website lists their coilovers for $1,250+Shipping - for the optional welding service, you have to send them a spare pair of front knuckles/spindles. I think it's an additional $100 dollars or so for the welding service (you'd have to contact them and verify).
If you need help sourcing an extra set of front knuckles/spindles, I can help you source a pair and ship them directly to Powertrix for you (I'll accept PayPal).
