link133 link134 link135 link136 link137 link138 link139 link140 link141 link142 link143 link144 link145 link146 link147 link148 link149 link150 link151 link152 link153 link154 link155 link156 link157 link158 link159 link160 link161 link162 link163 link164 link165 link166 link167 link168 link169 link170 link171 link172 link173 link174 link175 link176 link177 link178 link179 link180 link181 link182 link183 link184 link185 link186 link187 link188 link189 link190 link191 link192 link193 link194 link195 link196 link197 link198 link199 link200 link201 link202 link203 link204 link205 link206 link207 link208 link209 link210 link211 link212 link213 link214 link215 link216 link217 link218 link219 link220 link221 link222 link223 link224 link225 link226 link227 link228 link229 link230 link231 link232 link233 link234 link235 link236 link237 link238 link239 link240 link241 link242 link243 link244 link245 link246 link247 link248 link249 link250 link251 link252 link253 link254 link255 link256 link257 link258 link259 link260 link261 link262 link263 link264 link265
Rebuilding adjustable struts - need some info and pictures
  • volition
    volition
    Member
    • 31
    Hi everyone,
    I have read that the adjustable shocks were intended to be rebuildable using a no longer available rebuild kit. I'm gathering up information before I plunge into tearing my daily driver apart to experement. I've been an avoid mountain biker and have spent the last 10 years rebuilding shocks of all kinds and automotive shocks are built the same internally (actually, auto shocks are much more simple), and rebuilding simply comes down to finding seals that fit and getting the oil weight correct to achieve the damping you're after.
    First, does anyone have some pictures of a removed cartridge? I'm curious to see the entry point and how the actual cartridge is supposed to come apart if indeed they were designed to be rebuilt using a kit (it is possible they have to be CUT open).
    Second, does anyone have experience trying specifically on Z31 ADJUSTABLE cartridges? I know for a fact non turbo cartridges don't come apart already.
    Thanks for your help.
  • G-E
    G-E
    Junior Member
    • 6320
    The insert cartridge is a plain gray cylinder, it's held in by a gland nut with a complicated seal arrangement, a rebuild would consist of an entirely new insert and/or gland nut… I'm pretty sure it's all NLA anyway.
    Any reason you don't want to just get koni or bilstein inserts?
  • volition
    volition
    Member
    • 31
    The plain grey cylinder is the actual damper unit which I'm interested in taking apart as it's what contains the valve assembly.
  • flatfoot
    flatfoot
    • 253
    I'm currious about this too.
    I ran across a 10 year old article in the break room at work about rebuilding old shocks with thicker shock oil to stiffen them up.
    It was in some british magazine where they were building cars entirely out of junkyard parts.
    Right now the DD is a GLL with the factory adjustable shocks that are blown and I have a set of SS springs I'd like to put on it and keep the electric adjustment parts working.
    Life's short
    Go fast
    Have a blast
    Leave a good looking corpse
  • jaqattack02
    jaqattack02
    • 1185
    #5
    If you mean the adjustable suspension that came on the turbo cars, as I understood it they haven't been made in a long time because some kind of fluid that was in them that made them work was deemed toxic by the EPA, so Nissan had to stop production of them.
    My 1986 Turbo Build
  • adamvann3
    adamvann3
    • 4160
    #6
    I had a fully working OEM adjustable suspension in my 85t. Removed everything to go with something else.
    Tell you what, $150+20 shipping and its all yours. You can experiment all you what for not a lot of $$$
    I removed the front struts from the inserts and packaged up everything in a couple of boxes.
    86na - BlueZ
    85t - Mr Tickles
  • aZinMA
    aZinMA
    • 146
    #7
    Curious if you had any luck....?
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #8
    No one's done it because they were not meant to be rebuilt, only replaced and replacements are NLA for at least 10 years.
    1991 Hard-body 2WD
  • khyronzx
    khyronzx
    • 1204
    #9
    Theres a couple pics on my facebook somewhere of the inserts apart. Mine pretty much fell apart upon removal so i dont think itd be hard to get them apart. Iirc the top cap was crimped on somewhat.
    "Beer is proof that god wants us to be happy" - Benjamin Franklin
  • G-E
    G-E
    Junior Member
    • 6320
    #10
    I'm sure it's possible, the only question is whether seals and things are available to do it, someone should disassemble one and make a list of all the parts that need replacing… we can then crowdsource solutions, matching up o-rings and such
    The "toxic" chemical is probably cadmium
  • floridaZ
    floridaZ
    • 2781
    #11
    Something somewhere is bound to work for a rebuild… seals and fluid. Figuring it out is gonna be a royal pain in the ass though.
    Feedback- viewtopic.php?f=18&t=19840
  • newsieone
    newsieone
    • 120
    #12
    There are reference books available at bearing and seal suppliers (probably in PDF nowdays) that will provide the part numbers, dimensions, specs, etc. of virtually every brg/seal ever made plus interchanges. Most often engineers will design a part to suit an existing brg or seal, rather than spec a custom size. Cost difference=$$$. A Fafnir ABC brg often will sub for an SKF, Timken, or Skoda. Same holds for seals. A National ABC seal will often sub for a Chicago Rawhide XYZ seal of the same dimension.
    Brgs are built to a class (#1>#7); higher # is better (and priced accordingly). Manufacturer is minor: SKF class 4=Nippon class 4.
    Seals are made in bunan (rubber), viton, and rawhide (Yep!)
    O rings come in a zillion sizes. A,B,C, etc.,# 1;2;3 etc. SAE, Metrics; dimentionals. And sold in rope coils for diy installs made to fit.
    86na
    88t
    machine build/rebuild-master
  • Rustspecs13
    Rustspecs13
    • 283
    #13
    You'll just have to experiment for yourself, and see if the info newisone pans out.
    S30's have more info on doing what you want to do as they used to have a nissan motorsports package that did the same thing. It had new shock oil, new seals and new springs.
    I actually did it on my 260z. I used engine oil and re used everything else. It was a cheap experiment when the shocks I bought didn't fit and my car still had the original shocks. The driver side held up for quite a while, but after 2-3 months of random daily driving they leaked out past the worn out seals. I refilled them once, and if I put it back on the road before I do coilovers, I'll refill them again.
    The 240 or 260z FSM has the exact procedure to fill and bleed the shocks properly, I would check that out as well.
    ~Alex
    splatter fake blood on fubar'd quarter and roll out.
  • volition
    volition
    Member
    • 31
    #14
    It's very do - able. You just have to replace the seals which are camshaft seals , don't recall the dimensions off hand something like 35 mm ID x 52 mm OD x 4 mm height . There are two of them inside the nut . You also have to refill the shocks with hydraulic fluid , ATF works perfect and will create a shock that's stiffer than stock, again don't recall the exact amount but I think it was 190ml.
