link1463 link1464 link1465 link1466 link1467 link1468 link1469 link1470 link1471 link1472 link1473 link1474 link1475 link1476 link1477 link1478 link1479 link1480 link1481 link1482 link1483 link1484 link1485 link1486 link1487 link1488 link1489 link1490 link1491 link1492 link1493 link1494 link1495 link1496 link1497 link1498 link1499 link1500 link1501 link1502 link1503 link1504 link1505 link1506 link1507 link1508 link1509 link1510 link1511 link1512 link1513 link1514 link1515 link1516 link1517 link1518 link1519 link1520 link1521 link1522 link1523 link1524 link1525 link1526 link1527 link1528 link1529 link1530 link1531 link1532 link1533 link1534 link1535 link1536 link1537 link1538 link1539 link1540 link1541 link1542 link1543 link1544 link1545 link1546 link1547 link1548 link1549 link1550 link1551 link1552 link1553 link1554 link1555 link1556 link1557 link1558 link1559 link1560 link1561 link1562 link1563 link1564 link1565 link1566 link1567 link1568 link1569 link1570 link1571 link1572 link1573 link1574 link1575 link1576 link1577 link1578 link1579 link1580 link1581 link1582 link1583 link1584 link1585 link1586 link1587 link1588 link1589 link1590 link1591 link1592 link1593 link1594 link1595
Steering slop and rear hub questions
  • Windzer
    Windzer
    • 335
    I have some slop in my steering after replacing all front bushings and tie rod ends. The wheels do not move if jacked up (and one wheel is on the ground, they move evenly if both wheels off the ground), and there is no play in the wheels. Aside from the rack being worn out, are there any u-joints in the z31 steering system I should be looking for? Going to do head gasket and oil pan seal in 3 weeks, so figured I would tackle this while the engine is out.
    Also, I am going to be doing poly bushings in the rear control arms, and the arms I have came with rear hubs but they were off a late model non turbo, will I need to swap my rear turbo hubs over, or will the 5 lug hubs on the control arms work?
    Thank you
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    Steering shaft linkage has a u-joint in and they wear out. There are two styles, 84-86 and 87-89
    1991 Hard-body 2WD
  • Windzer
    Windzer
    • 335
    Exactly what I was looking for. Going to check it out this weekend to see if I need the u-joint!
