link2660 link2661 link2662 link2663 link2664 link2665 link2666 link2667 link2668 link2669 link2670 link2671 link2672 link2673 link2674 link2675 link2676 link2677 link2678 link2679 link2680 link2681 link2682 link2683 link2684 link2685 link2686 link2687 link2688 link2689 link2690 link2691 link2692 link2693 link2694 link2695 link2696 link2697 link2698 link2699 link2700 link2701 link2702 link2703 link2704 link2705 link2706 link2707 link2708 link2709 link2710 link2711 link2712 link2713 link2714 link2715 link2716 link2717 link2718 link2719 link2720 link2721 link2722 link2723 link2724 link2725 link2726 link2727 link2728 link2729 link2730 link2731 link2732 link2733 link2734 link2735 link2736 link2737 link2738 link2739 link2740 link2741 link2742 link2743 link2744 link2745 link2746 link2747 link2748 link2749 link2750 link2751 link2752 link2753 link2754 link2755 link2756 link2757 link2758 link2759 link2760 link2761 link2762 link2763 link2764 link2765 link2766 link2767 link2768 link2769 link2770 link2771 link2772 link2773 link2774 link2775 link2776 link2777 link2778 link2779 link2780 link2781 link2782 link2783 link2784 link2785 link2786 link2787 link2788 link2789 link2790 link2791 link2792
Front camber question
  • Windzer
    Windzer
    • 335
    Just got brand new tires and an alignment. It shows the front right at -0.1 degree of camber, however, the front left shows -1.0 degree. Any ideas what to check to try to fix this?
    I have prothane bushings, new ball joints, new tie rod ends, stock springs, and illuminas. I am also running two different rims (found out one of my z32 rims was bent like a mofo, so I had to swap it out while I find a replacement.
    Can anyone give me an idea where to check to fix this -1 degree of camber?
  • jaqattack02
    jaqattack02
    • 1185
    Make sure bushings aren't worn out. Past that, short of something being bent, there isn't really anything to adjust/fix, at least that I can think of. Front camber is pretty much fixed on the factory suspension.
    My 1986 Turbo Build
  • Windzer
    Windzer
    • 335
    Brand new prothane bushings. If I didn't tighten the castle nut on the ball joint, could that have an effect? I somehow doubt it would be enough to give it 1 degree of camber, but that is the only thing I can think of.
  • adamvann3
    adamvann3
    • 4160
    I would try and fix the other side. Even -1 degree of camber is pretty weak for a McPherson setup.
    Could be a variation in about anything. Bushings and ball joints would give the greatest variance. Bent LCA or strut could cause this as well.
    Did you use new spring seats/bushings? How is the top mount bushing?
    86na - BlueZ
    85t - Mr Tickles
  • Windzer
    Windzer
    • 335
    #5
    Ball joints are new, both are the same brand and installed at the same time. No spring seats, and the top bushing I am assuming you mean the strut one? Pretty sure they are nonexistent. Everything between the two side is identical as far as I can see, so no idea why there is such a large difference. only easy answer is that there are two different rims on the car and maybe it's a difference in attachment?
  • NissanEgg
    NissanEgg
    • 5220
    #6
    Is one lower control longer than the other? That will give more camber on the longer arm. Difference in strut tubes have a different angle of the kingpin for the wheel bearings that changes camber.
  • Windzer
    Windzer
    • 335
    #7
    It should not be, they were pulled from the same car as replacement for mine. And were the same size when placed next to the parts they were replacing.
  • G-E
    G-E
    Junior Member
    • 6320
    #8
    There's really not much that hasn't been said, but could be a combination of little things if it isn't the obvious…
    Perhaps the subframe holes are egged? Maybe the spring isn't seated correctly on one side raising ride height affecting camber? What if your replacement wheel isn't 100% true?
    And the fsm clearly states about a 1 degree range of variability in struts, so it's also possible one strut is on the lower side, and coincidentally, the other is on the higher side… it is possible to have them measured, along with the straightness of the tube itself
  • frostvectron
    frostvectron
    • 1044
    #9
    Maybe suspension settling has to do with it?
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • Windzer
    Windzer
    • 335
    #10
    This is my lign of thinking. I am going to be getting brand new tires for the rears as well next month, so then I can have a matching set in front for testing. I did not see any egg shaped holes, but I can reinvestigate for sure. I also have had the side that is -1* taken apart several times due to swapping springs, then I put the spring in wrong, so I am going to check the driver's side to make sure that the spring is fully seated.
    These are all great suggestions and I appreciate the assistance!
  • Windzer
    Windzer
    • 335
    #11
    Here is hoping, the car was on a lift when they replaced the tires, and it was straight to the alignment shop ~2 miles driven distance
  • Windzer
    Windzer
    • 335
    #12
    I think we have a winner. I checked the height on the front and it looks like the side with 0* camber is about half an inch taller between the tire and the fender. Gunna take it apart next weekend and reseat everything.
  • cmgreen22
    cmgreen22
    Member
    • 97
    #13
    How did this turn out?
