link3857 link3858 link3859 link3860 link3861 link3862 link3863 link3864 link3865 link3866 link3867 link3868 link3869 link3870 link3871 link3872 link3873 link3874 link3875 link3876 link3877 link3878 link3879 link3880 link3881 link3882 link3883 link3884 link3885 link3886 link3887 link3888 link3889 link3890 link3891 link3892 link3893 link3894 link3895 link3896 link3897 link3898 link3899 link3900 link3901 link3902 link3903 link3904 link3905 link3906 link3907 link3908 link3909 link3910 link3911 link3912 link3913 link3914 link3915 link3916 link3917 link3918 link3919 link3920 link3921 link3922 link3923 link3924 link3925 link3926 link3927 link3928 link3929 link3930 link3931 link3932 link3933 link3934 link3935 link3936 link3937 link3938 link3939 link3940 link3941 link3942 link3943 link3944 link3945 link3946 link3947 link3948 link3949 link3950 link3951 link3952 link3953 link3954 link3955 link3956 link3957 link3958 link3959 link3960 link3961 link3962 link3963 link3964 link3965 link3966 link3967 link3968 link3969 link3970 link3971 link3972 link3973 link3974 link3975 link3976 link3977 link3978 link3979 link3980 link3981 link3982 link3983 link3984 link3985 link3986 link3987 link3988 link3989
Turbo crossmember differences?
  • cmgreen22
    cmgreen22
    Member
    • 97
    Courtesy Nissan has their turbo crossmembers under different part numbers. 84-86 turbo crossmember and 87-89 turbo crossmembers. Can someone with knowledge on this tell me the differences. Before I discovered this I assumed they were all the same. Thanks
  • Augustus Maximus
    Augustus Maximus
    • 1739
    The only difference I'm aware of is the 84-86 has wider (more desired) PS bracket on the driver side.
    http://www.garymolitor.com/300zx/SRB-Information1.pdf
    Cha iro
    at least you gave it a whirl.
  • jaqattack02
    jaqattack02
    • 1185
    I thought the only part that was different was the strap/hold down bracket? I didn't think the actual crossmember was different.
    My 1986 Turbo Build
  • Axel kain
    Axel kain
    Moderator
    • 1221
    ^bolt hole size difference I believe for the PS brackets.
    sigpic
