Response Type Adjustable front control arm conversion progress…
At the risk of sounding self serving, there's another use for this kit, and that is _shortening_ the control arm
For example: you have my offset rollcenter adjusters, which pushes the wheel out by ~11mm, perhaps that's a little too tight to the fender for you, so you dial it back in 5mm… you still gain the improved camber curve and caster effect, but less static camber and track width
