link532 link533 link534 link535 link536 link537 link538 link539 link540 link541 link542 link543 link544 link545 link546 link547 link548 link549 link550 link551 link552 link553 link554 link555 link556 link557 link558 link559 link560 link561 link562 link563 link564 link565 link566 link567 link568 link569 link570 link571 link572 link573 link574 link575 link576 link577 link578 link579 link580 link581 link582 link583 link584 link585 link586 link587 link588 link589 link590 link591 link592 link593 link594 link595 link596 link597 link598 link599 link600 link601 link602 link603 link604 link605 link606 link607 link608 link609 link610 link611 link612 link613 link614 link615 link616 link617 link618 link619 link620 link621 link622 link623 link624 link625 link626 link627 link628 link629 link630 link631 link632 link633 link634 link635 link636 link637 link638 link639 link640 link641 link642 link643 link644 link645 link646 link647 link648 link649 link650 link651 link652 link653 link654 link655 link656 link657 link658 link659 link660 link661 link662 link663 link664
Tire options?
  • wbnethery3
    wbnethery3
    • 437
    Tire options?
    So I've got stock '86 rims and I'd like thoughts on best choice for both size and brand of tire. Not looking to drift, don't have a turbo (yet) just looking for a reliable tire and don't want to blow the budget. Car had 215/65-15 on three wheels and 235/65-15 on one (PO did that). Discount says stock is the 215/60 so I guess he went a bit taller in addition to mixing widths. I will probably get larger wheels for appearance eventually but for now the taller/wider 235/65 might be a good compromise. I know it will throw the speedo off but I'm not worried about that.
    What say ye?
    '86 NA - original owner (1986-93) and final owner (2005-present)
  • Axel kain
    Axel kain
    Moderator
    • 1221
    I prefer Falken for their performance to cost. ZE or ZX series are a great touring style tire, tacky, but dont burn off too quick, and are usually $70-$90 each!
    sigpic
  • frostvectron
    frostvectron
    • 1044
    215/60/15 is already a pretty big sidewall… not sure what the benefit of going with an even taller tire is. My vote is to just get 215/60/15 for now until you get different wheels.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • wbnethery3
    wbnethery3
    • 437
    I did. When I went to Discount, they don't sell a 65 profile so I got 60's.
  • i r teh noobz
    i r teh noobz
    • 1046
    #5
    Taller tires fill the wheel well a little bit and make the car look better. 225/55s looked much better than 225/50s on my 88T.
    I had some Potenza G019s on my 85. Decent traction, worked well in snow and rain, rode smooth enough and were fairly quiet. They do tend to chop if your alignment is bad or they are not rotated regularly, so beware. Sams Club used to sell them for under 100 each. A friend is running some old RE92s on his Subaru and they have held up well, the RE97 is available now. I have no idea what they cost.
    5.3 LSx Z31
  • wbnethery3
    wbnethery3
    • 437
    #6
    Ended up with 225/60 cheapies from Discount. They have a directional tread and carry the speed rating, but we'll see how well they drive and wear. Agree that the taller tire probably looks better in the wheel well, but I couldn't get any and Discount wouldn't mount them if I had bought them online and brought them in. I could've used a different shop, but it wasn't that important to me. This is just a short-term solution, so I don't feel too bad spending less than $400 to get back on the road. Longer term I'm looking to go up in wheel size and get good tires… of course, that has to wait until it's in better shape.
  • wbnethery3
    wbnethery3
    • 437
    #7
    One other thing I'm considering - spacers. I think the stance with the stock wheels is a little narrow, and something to widen maybe 1" overall wouldn't hurt. Anyone use spacers on stock wheels?
  • frostvectron
    frostvectron
    • 1044
    #8
    Yup. 1" adapters work well on stockies.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • i r teh noobz
    i r teh noobz
    • 1046
    #9
    25mm/1" look great with stock wheels.
    5.3 LSx Z31
  • wbnethery3
    wbnethery3
    • 437
    #10
    So just to clarify - you're speaking of 1" thick spacers (x2) to widen the overall stance by 2"? Is that both front and rear? I'm going to buy locally so I can return if I don't like the look, but I'd rather not waste time. This will require I replace the studs as well, so help me understand what my options are there as well.
  • Pace
    Pace
    Moderator
    • 1108
    #11
    Get hub-centric adapters instead of spacers. Then you won't have to mess with extended studs and everything will bolt right up. Mine took 25mm fronts and 32mm rears to get 86T wheels "flush" with the fenders.
    '86 300ZXT GLL
    '78 Datsun 280Z BP
    '11 Saab 9-3 Aero XWD
  • wbnethery3
    wbnethery3
    • 437
    #12
    Good info… Thanks!
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    #13
    I used 25mm in the rear and 20mm in the front on SS 820 and it made the battleship that you get with stock wheels a lot less noticeable.
    http://z31performance.com/showthread…l=1#post279899
  • frostvectron
    frostvectron
    • 1044
    #14
    Check ebay.... cheaaap. I picked up hubcentric ones for like 60/pair shipped.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • bdleonard
    bdleonard
    Junior Member
    • 26
    #15
    If those are the Ohtsu FP6000, that appears to be the tire that used to be sold as the Falken ZE-512, another one of the companies under the Dunlop/Sumitomo umbrella. The Falken was a decent all-season tire, but nothing special. They may have changed tread compounds, since the rating has gone from 360AA for the Falken to 420AA on the Ohtsu. However, they may have just tested out slightly differently.
