link1330 link1331 link1332 link1333 link1334 link1335 link1336 link1337 link1338 link1339 link1340 link1341 link1342 link1343 link1344 link1345 link1346 link1347 link1348 link1349 link1350 link1351 link1352 link1353 link1354 link1355 link1356 link1357 link1358 link1359 link1360 link1361 link1362 link1363 link1364 link1365 link1366 link1367 link1368 link1369 link1370 link1371 link1372 link1373 link1374 link1375 link1376 link1377 link1378 link1379 link1380 link1381 link1382 link1383 link1384 link1385 link1386 link1387 link1388 link1389 link1390 link1391 link1392 link1393 link1394 link1395 link1396 link1397 link1398 link1399 link1400 link1401 link1402 link1403 link1404 link1405 link1406 link1407 link1408 link1409 link1410 link1411 link1412 link1413 link1414 link1415 link1416 link1417 link1418 link1419 link1420 link1421 link1422 link1423 link1424 link1425 link1426 link1427 link1428 link1429 link1430 link1431 link1432 link1433 link1434 link1435 link1436 link1437 link1438 link1439 link1440 link1441 link1442 link1443 link1444 link1445 link1446 link1447 link1448 link1449 link1450 link1451 link1452 link1453 link1454 link1455 link1456 link1457 link1458 link1459 link1460 link1461 link1462
steering knuckle
  • sp3cialfx
    sp3cialfx
    Member
    • 34
    steering knuckle
    I'm trying to remove the front left strut/tube but I'm having a hard time seperating the knuckle arm from the strut tube above it. Am I missing something? its got to be held on by something other than the two bolts in the FSM mentioned because it won't budge at all. I've unhooked the tension rod and the sway link as well. Does the ball joint underneath it somehow hold the tube there also?
  • G-E
    G-E
    Junior Member
    • 6320
    Brace the hub and strut against something solid and smack the knuckle sideways to try turning it, don't try smacking it down it will just bind.... alternately leave the tierod on and smack the hub sideways
  • sp3cialfx
    sp3cialfx
    Member
    • 34
    thanks got it off, could've swore the thing was welded on
