Rear Spring Replacement
rsmanJunior Member
- 3
Hey guys I have been re building my 300zx I bought a few months ago finally on suspension after doing fuel problems then brake problems. I am trying to replace the Rear springs on my car and cant get them off. I am using spring compressors but it seems that its not compressing it enough to be able to pop off. I looked for a how to but cant find one. if you know of one can you comment the link. if not does anyone have some advice and maybe pictures.
Thanks,
RS Man -
Augustus MaximusSenior Member
- 1739
Did you pull the shocks.Cha iro
drb5721Senior Member
- 289
You could always un-bolt the rear shocks and let the rear subframe weight lower itself and from there work the spring out. Thats what I had to do. I also had the diff unbolted at the same time so there was nothing supporting the subframe in that area. There may be other options, but this is how mine came out easiest -
rsmanJunior Member
- 3
PrideZ31Senior Member
- 328
We did this process on mine.
Remove the axle from the side with the spring you're trying to remove.
Place a jack under the control arm, and jack until you can remove the rear shock bolt.
Very slowly lower jack. Make sure you have something to keep the spring from jumping out if you don't have the spring compressors.
Got them out and in that way…__________________________________________________ ___________________
"Aim towards the Enemy." -- Instruction printed on US Rocket Launcher
86 N/A:Rebuilt Autotragic, Cat Delete, PRW-2, Poly Bushings, MSA sway bars, Pioneer HU and Speakers, Sleepy Eyes
Current 0-60: 10.0 flat =[ -
frostvectronSenior Member
- 1044
No need to unbolt the diff when I did it.
Unbolt the shock. Then get the scissor jack from the spare tool kit and wedge it between the top of the control arm and the body (be careful of the brake lines). Give it a few turns which will push the control arm down. Doing this and using spring compressors you will be able to pull the spring out no problem. -
rsmanJunior Member
- 3
okay good stuff ill give those a shot this weekend hopefully last thing before the car can drive on the street -
amrebootBanned
- 9875
I have never had issues removing the rear springs before.
Never had to unbolt the shocks or diff.
I have cheap harbor freight spring compressors and they work just fine.
I had to get them each half way around the spring so that its an equal 50/50 compression.
But I suppose to make it easier would be to unbolt the bottom of the shock.
best places buy seeds. -
- 289
Keep in mind the reason my diff was unbolted was because it was being pulled to swap in LSD carrier. No other reason. I have no doubt that using the proper spring compressor will work. Unbolting the shocks should just allow for less spring compression to get the spring out. -
Kimbro SliceSenior Member
- 1561
Unbolting the bottom of the shock and then using your weight to push the trailing arm down should give the spring enough room to remove it without the need for a spring compressor.
2001 Mazda Miata LS
also a 1989 Nissan 240SX
flatfootSenior Member
- 253
Don't forget to disconnect the swaybar as well as the lower shock mount before you push it down.Life's short
Go fast
Have a blast
Leave a good looking corpse -
Axel kainModerator
- 1221
Dont need spring compressors, with the shock unbolted from below, and the end link undone, just a little push down on the control arm, and the spring will FALL OUT of it's hole!Damn dirty angels....these cars!
sigpic -
FilipeSenior Member
- 524
SMH. I didn't realize there's a rear sway bar? SO obviously I didn't undo the end links. It was a PITA. HUGE PITA. But doable.
