Rear Camber Modification Write Up + Photo
  • DeleriousZ
    DeleriousZ
    • 6874
    Really enjoy this build and all your hard work man. Keep it up!!
    1990 jetta vr6'd
  • james
    james
    • 978
    adamvann3;339957 wrote: Damn, great work and a very impressive/perfect specs for a semi trailing arm (especially lowered!). Congrats on all the hard work!
    When you go back, increase your front camber to -2 to -2.5. My last alignment I increased from -1.7 to -2.5 and was pleased with the turn in response.
    Yeah i need to drop the front a little lower / flush wheel gap now that i have made a new down pipe that doesn't hit the ground, My ASCO plates were nearly maxed out to get -1.5 at approximately 1" lower than stock. But last time i had the coil overs would fully down i was able to get -2.5
    The Real sucess is that my rear suspension can go lower, and I still have more adjustment on the toe side to use. The camber side is set to exactly 1/2 way down its slot. I will be ripping the shit out of the poly bushings in there, but after an alignment I am now satisfied to spend a couple of hundred on the Aurora spherical bearings i would like to install.
    Doing the Toe side MOD alone would actually help people out more than doing the camber mod.
    Powered by Fund Solvaren.
    85 Turbo Slick Top
  • MADMIKE
    MADMIKE
    • 1533
    Drudging up an old thread, but did anyone save an offline copy of Gary's link to the more basic camber mod setup. It was a pretty detailed write-up, and I liked the simplicity of the setup
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • adamvann3
    adamvann3
    • 4160
    He has all the pictures necessary on the 1st page.
    His latest camber mod is still available via PDF
    http://www.garymolitor.com/300zx/cam…ber-mounts.pdf
    86na - BlueZ
    85t - Mr Tickles
  • 1artworkz
    1artworkz
    • 1143
    Gee, I totally forgot I did that write-up.
