link122 link123 link124 link125 link126 link127 link128 link129 link130 link131 link132 link133 link134 link135 link136 link137 link138 link139 link140 link141 link142 link143 link144 link145 link146 link147 link148 link149 link150 link151 link152 link153 link154 link155 link156 link157 link158 link159 link160 link161 link162 link163 link164 link165 link166 link167 link168 link169 link170 link171 link172 link173 link174 link175 link176 link177 link178 link179 link180 link181 link182 link183 link184 link185 link186 link187 link188 link189 link190 link191 link192 link193 link194 link195 link196 link197 link198 link199 link200 link201 link202 link203 link204 link205 link206 link207 link208 link209 link210 link211 link212 link213 link214 link215 link216 link217 link218 link219 link220 link221 link222 link223 link224 link225 link226 link227 link228 link229 link230 link231 link232 link233 link234 link235 link236 link237 link238 link239 link240 link241 link242 link243
strut and springs change out -help
  • jerryparks
    jerryparks
    • 242
    URGENT !! I need to know if '86 non turbo springs and struts will fit my 87 ZX turbo? I have got to obtain a smoother ride. I'm getting older and the rough ride is hard on my older body ! I have an 86 part car and thought I would just change out the parts. Help! I want to do this in the next couple days.
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    The entire 86na Macpherson strut assembly will be a direct swap to the 87 turbo. Just remove it at the 2 17mm* bolts from the steering knuckles,and at the 3 14mm* nuts on the upper mount.
    *wrench size, not thread diameter.
  • jerryparks
    jerryparks
    • 242
    Thanks Karma. This will save me a lot of work. - Jerry
  • jerryparks
    jerryparks
    • 242
    Karma: Are U sure no other bolts will have to be removed to take these out?
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    #5
    I'm 99% sure that i'm 80% certain.
    You will have to use a screwdriver or pliers tp unclip the brake line retainer from the strut tube. You will also need to un -bolt the caliper bracket. That's 2 more 17mm bolts.
    The lower control arm will be kind of held firm against the bottom of the strut assembly, a few whacks with a dead-blow mallet or rubber hammer should help separate it.
    http://www.xenonzcar.com/z31/fsm.html
    Disassembly instructions are in the FA section of the FSM(s) linked above.
