Ride refresh
Ohio_82Junior Member- 15
Ride refresh
So im finally getting around to replacing my sub frame bushings and im wondering if while im at it i should just replace the shocks and springs all the way around. This is an 88 na car with a manual transmission. Im not planning a turbo swap or really any major engine upgrades this is just going to be a weekend cruiser type car. So what would be the best bang for the buck? Should i do the poly busbing kit as well? -
ZuphoriaJunior Member- 26
Are the Shocks in the rear original? Replace them for sure! Z31 are terrible for rear suspension components needing replacement. Do all you can afford when you have the Sub Frame out!!
