link1197 link1198 link1199 link1200 link1201 link1202 link1203 link1204 link1205 link1206 link1207 link1208 link1209 link1210 link1211 link1212 link1213 link1214 link1215 link1216 link1217 link1218 link1219 link1220 link1221 link1222 link1223 link1224 link1225 link1226 link1227 link1228 link1229 link1230 link1231 link1232 link1233 link1234 link1235 link1236 link1237 link1238 link1239 link1240 link1241 link1242 link1243 link1244 link1245 link1246 link1247 link1248 link1249 link1250 link1251 link1252 link1253 link1254 link1255 link1256 link1257 link1258 link1259 link1260 link1261 link1262 link1263 link1264 link1265 link1266 link1267 link1268 link1269 link1270 link1271 link1272 link1273 link1274 link1275 link1276 link1277 link1278 link1279 link1280 link1281 link1282 link1283 link1284 link1285 link1286 link1287 link1288 link1289 link1290 link1291 link1292 link1293 link1294 link1295 link1296 link1297 link1298 link1299 link1300 link1301 link1302 link1303 link1304 link1305 link1306 link1307 link1308 link1309 link1310 link1311 link1312 link1313 link1314 link1315 link1316 link1317 link1318 link1319 link1320 link1321 link1322 link1323 link1324 link1325 link1326 link1327 link1328 link1329
Turbo crossmember and core support questions
  • edizzle89
    edizzle89
    Member
    • 82
    I am currently getting ready to swap an LS into my 87t car. One thing I am needing to know is what is the measurement of the offset for the motor mounts on the turbo crossmember. I know the driver side is further forward but how far forward is it? I have some adjustable motor mounts i've been working with that I think i can make work but their maximum offset is ~6.5 inches and im wanting to know if i need to modify them more to make them reach further.
    Also how vital is the core support (the cross piece with the hood latch and that the upper radiator hose passes through) to the structural integrity of the chassis? I have seen several people with them cut out and haven't read anything about it causing a problem. Cutting it out would make alot of things much, much more simple for me but i dont want to ruin the chassis by doing so.
    if you're gonna be dumb you gotta be tough
  • edizzle89
    edizzle89
    Member
    • 82
    well i did some rough measurements of the mount offset in the car, looks like they are offset by about 5.5 inches so i should be good with the motor mounts on my LS.
    Still looking for info on if cutting out the core support between the headlights will have any notable effects on the chassis.
  • Dunkine
    Dunkine
    • 255
    Yes, just like adding a strut tower bar stiffens up the front, chopping out the core support is going to lose the only high structural "cross tie" forward of the cowl.
  • kaur
    kaur
    • 310
    Perhaps you could cut the support and replace it with a bolted brace. Then you can remove it to make space and put it back when you're done.
  • edizzle89
    edizzle89
    Member
    • 82
    #5
    yea i might look into making a bolt in brace, will also probably add a strut tower bar since it wont hurt to have.
  • Dunkine
    Dunkine
    • 255
    #6
    Was checking out https://z31world.wordpress.com/categ…ssan-spotting/ and found a pic of a brace. Not the best looking, but functional.
  • FrozenZ
    FrozenZ
    • 584
    #7
    I'm not a suspension/chassis expert but that doesn't look like it's going to do much compared to the stock section. That tower bar looks pretty beefy though, maybe it trades off…
    • Dunkine
      Dunkine commented
      Yeah, pretty thin metal and not boxed at all, but I guess something is better than nothing.
