Will these wheels fit ???
NewJerseyZSenior Member- 191
A friend of mine keeps trying to help me get better tires and brakes for my modified 1985 Z31 Turbo. Although I appreciate his efforts and understand that better handling and brakes are a nice addition to having more power, I'm not quite sure that what he's suggesting will fit. He's suggesting 8" wide Enkei PF01 17 inch with 235/45/17 tires. I personally don't think I have the inner clearance, but perhaps some here might know what my limits are with wider/taller wheels. Thank you. -
FlawleZSenior Member- 1971
What's the offset and bolt pattern? Most 5x114 wheels fit our cars, but most have positive offsets which sink deep into the fenders due to our cars running a low offset stock.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
DunkineSenior Member- 255
Check out http://www.thezenthusiast.com/wheelshow.html
Has the factory specs and you can look at what others have run.
You could run spacers for those or just get wheels with the right offset. -
areebashar.23Member- 48
