FR 500 Wheels
TurboZkidSenior Member- 395
FR 500 Wheels
what do you think of these wheels on my 88t? im scoring them off a buddy with bf Goodrich street radials on them for 600..i believe they are 10 in the rear 9 in the front with a 275 rear and 245 front…what do you guys think the offset will look like?
Andrew84zxSenior Member- 1110
how are we suppose to tell you "what the offset will look like" by this i guess you meen will they be battle ship or not, if you dont post the offset…durrI hate wheel gap with a extreme passion
my build
viewtopic.php?t=2755
seller feedback
viewtopic.php?f=18&t=10430 -
ButterSenior Member- 1519
reddzxSenior Citizen- 6440
If you buy them before figuring the offset fit, you get what you deserve. That's a pretty wide wheel to be guessing. are they 18", 19" or 20". That makes a difference on the offset.
A quick search tells me they come in many different offsets from +24mm to +45mm. Look inside the wheel on the rim for a number. If they are over 18" I'd pass because of the fender lip clearance issue.
1991 Hard-body 2WD
DeleriousZSenior Member- 6874
those look like signal12's old wheels?
1990 jetta vr6'd -
adamvann3Senior Member- 4160
Why dont you tell us? If you can pull them off they will look good on your car but I am guessing you will need a spacer of sorts without ordering the correct offsets. They may work being that they are from a muuuustang, who knows…TurboZkid wrote: …what do you guys think the offset will look like?86na - BlueZ
85t - Mr Tickles -
i dont yet know what the offset is im going to get a better look at em tomorrow…u say the offset number is on the back of each wheel? to be flush i need an offset lower or higher than 18?
88sinZSenior Member- 2019
i had the bullett's from American muscle, decent wheels but pretty heavy at 54lb's each on 18x9's with 245/40's.. in the end you should save your money and get something better -
vagabondSenior Member- 3455
HA, that's a funny question.
+1
+1
+1
+1
( for buying wheels with no clues as to the offsets.
Style: FR500
Finish: Black
Back Spacing: 6.2" (157mm)
Offset: +30mm (1.2")
Centercap Size: Large (2-1/2")
Bolt Pattern: 5x4.5" (5x114.3mm)
Powered by Fund Solvaren.
NismofreakMember- 80
I too had the bulletts from American Muscle… With the same size tire they weighed 52lbs in the front (18x9) and nearly 60 lbs with 275/35 in the rear (18x10).88sinZ wrote: i had the bullett's from American muscle, decent wheels but pretty heavy at 54lb's each on 18x9's with 245/40's.. in the end you should save your money and get something better
For flush you will need an adapter in front. There is no doubt. In the rear, you might need a spacer.
ShamWowSenior Member- 1905
So 9" wide et+30 on a Kouki?
1" adapter's all around and at least people won't laugh at you.
Actually people will still laugh. Just get different wheels. and add in "Jenny Craig" or "slim fast" to your search query."produce first.talk second." -
LOL, to get a 18x9 flush on a Kuoki the offset needs to be close to 0et. I was running -1.4mm offset on mine.Mike_GruiZinga wrote: 1" adapter's all around and at least people won't laugh at you.
Yes. Flush with wide tires = 0et on 9" for Kouki. Make it poke… -10et
It's funny i was looking at this table the other day that seemed to suggest +20et was the furthest you could go out.. hmm :nanan?re"produce first.talk second." -
those are the same wheels Signal12 had on his SS at one time. He sold them and got something else before selling his car.
http://www.cardomain.com/ride/2168752/2
