quick info
862sikSenior Member- 2159
quick info
http://im1.shutterfly.com/media/47b9da2 … /ry%3D480/
thats my rear control arm.
i was reading and people said leave the sleeve for the front control arm, but remove the rears.
but if i remove the rear sleeve then the bushing will have "play" where right now its pretty snugg. can anyone help?
thank you.My Build Thread -
yea then i read this and it threw me off
viewtopic.php?f=2&t=11207&hilit=sleeve+confused
so you leave the outer sleeves in both?People get confused. Leave the sleeve in on the LCA's and remove it from the crossmember.My Build Thread -
vagabondSenior Member- 3455
I left my "sleeves" in. Lubed the bushings good and pressed them in. Very tight, no issues.
Best pic I have:
thank you! ill do the same.
lol that rear crossmember bushing was a pain, mine was very good condition but the sleeve was rusted in…gold ol' air hammer did the trick though.My Build Thread -
DeleriousZSenior Member- 6874
gary's install instructions specify to remove the sleeves.
they were rusted in on mine, it was a royal beyotch. i kicked the shit out of the crossmember while doing it. luckily i'm installing solid mounts, because the poly bushings would get torn up.
1990 jetta vr6'd -
turblownSenior Member- 400
Sorry to bump an old thread but spotted this while searching for subframe bushing info (I'll be replacing mine this week). So, at least one person left the sleeve in on the rear subframe. Any others? If mine gives me a fight do I absolutely have to remove it? (I know all the guides say to, but I'm just asking since I see here that one person didn't).
1985 300ZX Turbo GLL ^Click for log^
Originally posted by nater86zxNo such thing as hoarding Z parts. When it comes to z parts, its not hoarding its preparedness! -
adamvann3Senior Member- 4160
Air chisel. Make it your bitch.turblown wrote: Sorry to bump an old thread but spotted this while searching for subframe bushing info (I'll be replacing mine this week). So, at least one person left the sleeve in on the rear subframe. Any others? If mine gives me a fight do I absolutely have to remove it? (I know all the guides say to, but I'm just asking since I see here that one person didn't).86na - BlueZ
85t - Mr Tickles -
Axel kainModerator- 1221
the 4 i've done, a cruddy big flat blade/chisel, hammer and about 5min, and theyre out. rusted in or not! worst one took maybe 10 min…Damn dirty angels....these cars!
sigpic -
easiest way. use a chisel to bend an edge over. use a 3 inch spike/nail and put it behind the chiseled part until you make a nice enough place to shove some needle nose vice grips or pliers.
grab pliers real good. give it a nice "spin", and the sleeve will just peel itself from the sides pretty easy.
