Tokico Illumina front strut installation trouble
XiOus271Senior Member- 362
On my 86T, I am just getting around to installing my Illumina front struts. The passenger side cartridge went in quite easily, I did not really have much trouble with that. However, I was doing the drivers side today and that damn thing has about 1/8" to go before the gland packing can reach the threaded section. For fear of causing some damage, I have held off on trying anything else. What have you guys done when installing these? I looked at my FSM, spent some time on Google, but I would like to hear from some of you as to how you did it. I realize it is something as simple as getting it down the tube, but I don't like taking chances on screwing suspension/brake components. Thanks.1986 300ZX Turbo - Sold
1991 Toyota MR2 - RIP
2007 BMW 335i - Daily driver -
NissanEggSenior Member- 5220
Did you drain all the old fluid out of the tube first?
Yes I did. I followed the procedures outlined in the FSM.1986 300ZX Turbo - Sold
Based on what I am reading and seeing, these should not have to be forced into place. Is this correct?1986 300ZX Turbo - Sold
vagabondSenior Member- 3455
Domdogg123Senior Member- 491
Make sure the O-ring isn't gumming up you sliding it down.It may not be a Z, but it's still got a turbo… -
I would get in there with a flash light and made sure there is no debris lodged down in the bottom. Also, make absolutely sure that the tube is not dented.
Update: I took the strut housing and cleaned the hell out of it. The cartridge went in much easier and I managed to everything put together. However, if I ever need to take it out, it seems like that won't be a very fun job as the last little bit was still pretty tight. I decided simply cleaning it when I took the old one out wasn't enough, it needed a damn good scrubbing and it worked from there. Thank you all for your input.1986 300ZX Turbo - Sold
GregmaticSenior Member- 2193
sometimes the cartridge needs to be sanded just a bit. Removal is easier than you think. Just thread the top nut over a large washer and hang that in a vice. Tap gently on the spindle portion of the housing (or on the caliper mounting ear) and it will usually slide right off. Apply a bit of heat/penetrant as needed if needed. This will also keep the shaft from getting damaged
I'm going to have to remember that one, sounds pretty good to me. Thanks again!Gregmatic wrote: sometimes the cartridge needs to be sanded just a bit. Removal is easier than you think. Just thread the top nut over a large washer and hang that in a vice. Tap gently on the spindle portion of the housing (or on the caliper mounting ear) and it will usually slide right off. Apply a bit of heat/penetrant as needed if needed. This will also keep the shaft from getting damaged1986 300ZX Turbo - Sold
Another thought is to apply a little anti-seize on the tube before sliding it in..
Not too much to cause trouble, but something to keep things from sticking together..
These are good tips, as I also have a set of illumina's waiting to go into a set of turbo tubes..Kevin
1986 NA 5sp - Bone stock, but in good shape
