How would these wheels look on an SS?
Rick88ssSenior Member- 2433
all four wheels 17x9 24mm offset but
The wheels in the pics are 17x8.5 45mm offset and 17x10 45mm offset
Shiro #443
vagabondSenior Member- 3455
supertoad120Senior Member- 165
Depends on size but I like the style.1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
viewtopic.php?f=13&t=15468 -
http://www.rbwheels.com/index.php?main_ … ts_id=1996
but somewhere else they're selling four of the same wheel in
17x9 24mm offset for less
I'll go with these betterShiro #443
They're a direct fit on an 88 Z31(17x9 24mm offset). Maybe a small spacer on the back wheels to make it flush with the edge of the 1/4 panelShiro #443
I was referring to these.Rick88ss wrote: The wheels in the pics are 17x8.5 45mm offset and 17x10 45mm offset
The others set would be the best bet, obviously.
acemanSenior Member- 1566
when considering size, compare to people with 2003 cobra wheels. they are a 17x9 et27Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
Will need at least a 15mm spacer. IMO a 20-25mm spacer would be best.Rick88ss wrote: all four wheels 17x9 24mm offset
Guest -
[quote]Racinjitter wrote:I'm sure I'll put some spacers in the back. What's a good place to get some? Do I also need longer wheel studs?Originally posted by Rick88ssall four wheels 17x9 24mm offset Will need at least a 15mm spacer. IMO a 20-25mm spacer would be best.Shiro #443
You could get hub centric adapters. They bolt on to the hub and have threaded bolts for the wheels.
As an alternative to getting longer studs. I used Airwolfe racing on eBay. You can contact them for custom sizes and specifications. About $125 a set (2) shipped.
+1300cars wrote: Would look a lot better with some more lip.1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
adamvann3Senior Member- 4160
Reminds me of work meisters. There is a pic of a black zenki with gold meisters on them floating around somewhere. Go for it, they should look awesome. I am also looking for some gold with a polished lip for the SS.86na - BlueZ
85t - Mr Tickles
