84-85 Turbo + NA Shift Knob Differences
  • jdmlegends
    jdmlegends
    • 137
    Someone once told me that the shift knobs were different on the 84-85 Turbo and NA. However, I think they must mean the threads on the sticks of the T-5 and 71C. In essence, you can't use an 85 Turbo shift knob on a 71C and vice versa. Can anyone confirm?
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    You could get the correct thread tap and tap to fit whatever one is smaller, but they do have different part numbers for the NA/Turbo manual trans shift knobs, for the same color code interior.
  • jdmlegends
    jdmlegends
    • 137
    I thought so. I wanted to make sure for whenever I get around converting the 84T to manual. I found a shift boot and shift knob for it, but they're from a BW T-5 turbo model, but I'd probably be looking at using a 71C or 30a. Nissan always has such uncommon, high tech parts names. I would have entered shift knob in the search box but you found Knob-Control Lever lol.
  • Dunkine
    Dunkine
    • 255
    The different part #'s could also be because they have different shift patterns for reverse on top. The turbos step over and the N/A go straight from 5th to reverse. Shafts could be different too.
    Check out http://www.300zxpartsforyou.com/ Page 23
  • kaur
    kaur
    • 310
    #5
    What Dunkine said, the shift patterns are different. One is symmetric, the other has a step for the reverse.
