Center Reflector Mod ? Zenki taillights
jy1235689Member
- 59
Has anyone seen this "300ZX" center light done as a mod , or am I looking at an aftermarket / fully custom part? I know I can't make the red part light up (or can I?) Because the reflector has black plastic injected behind it. ( Zenki)
I found this pic on CarDomain so that was no help.
Edit: wrong section, needs to be in upgrades.Last edited by jy1235689; 08-12-2019, 10:45 PM.1984 GLL 300ZX NA to VG30ET Engine Swap Big Turbo
1987 Auto Rare Kouki Slicktop Velvet-Cake (NA2T in progress: parts sourced) -
Z_KarmaAdministrator
- 3318
Totally doable by disassembling (it can be carefully separated) and sanding off the silver backing on the letters and back-lighting with LED.
I did one many years ago using a cold cathode tube from a flatbed scanner, but never installed it on the car and used it as a bench light. Leds are a much better choice now,
- 1 like
jdmlegendsSenior Member
- 137
I thought about doing this mod but was worried about cracking the reflector when separating it. I also wasn't sure where to get the aluminum backing to reflect the light. -
FlyingTSenior Member
- 1095
Scott
93 NA Babied
- 1 like
jy1235689Member
- 59
Well turns out my search skills are terrible if it was on xenonz31! Thanks!1984 GLL 300ZX NA to VG30ET Engine Swap Big Turbo
