Boost problems
  • barkrz18
    barkrz18
    Member
    • 30
    Boost problems
    I have installed a few upgrades to wind the boost up
    Following mods - Walbro fuel pump
    Malpassi fpr
    near new stock injectors
    Profec spec b boost controller
    new leads and plugs
    new water pump and timing belt
    I have turned the fuel pressure up to 42psi and i think stock was 36. I turned the boost up on the controller also and when i took it for a drive i noticed the once it went over 11psi it would start lagging and not boosting properley. i have read up about whinding boost up and i was sure i done everything correct.
    anyone know if i am missing something?
  • BLOZ UP
    BLOZ UP
    • 2971
    Not boosting properly? Gap too high? Although, at 11psi, I doubt it.
    BLOZ UP.com
  • barkrz18
    barkrz18
    Member
    • 30
    shouldnt the gap on plugs be right since the are new? it feels real good up until it goes over 10 psi and it starts running sluggish and lagging heaps.
    Would my lifters ticking hard be the reason why this could be happening?
  • Tempestas
    Tempestas
    • 225
    considering you listed everything else… do you still have a pop off valve installed? That would open up, dump the air, cause excessive rich condition…
  • sprtcrazy17
    sprtcrazy17
    • 1685
    #5
    It wouldn't go over 8psi if that were the case. I wouldn't run over 10psi without an intercooler personally. I've seen bad things happen.
    What plugs did you install? Stock NGK should be used
  • BLOZ UP
    BLOZ UP
    • 2971
    #6
    barkrz18 wrote: shouldnt the gap on plugs be right since the are new? it feels real good up until it goes over 10 psi and it starts running sluggish and lagging heaps.
    They are usually pre-gapped, but I always check before I pop them in.
    I was wondering if you were blowing sparks out. I doubt it, but it's possible. So, either that, or it's running too lean or rich. I would find out before you try it again.
    BLOZ UP.com
  • DMANN
    DMANN
    • 544
    #7
    Lifters ticking hard??? Sounds like detonation! You upgraded the fuel pump but not the injectors?
    Whats the timing set at!
    I can't run past 9psi on my stock 87t before it starts running lean, and starts to denonate!
    Just a thought.
    88na2T-s13,q45 swap 12.6@110mph
    87T 2+2 auto,stock
  • Mitchd03
    Mitchd03
    • 891
    #8
    Get an intercooler.
    In fact, take a video of it so we can see what happens 1st hand.
  • Robyr
    Robyr
    • 751
    #9
    I am having a hard time believing his motor is detonating at 11psi. There has to be an underlying cause if it is, because no VG ive ever had cared about 10ish psi. I'd still STRONGLY suggest looking at your fuel, and any vacuum leaks as that would definitely not help you.
  • nismopu
    nismopu
    Administrator
    • 2221
    #10
    Mine did this as well for a short bit and it tunred out to be the factory POP off valve bleeding off. Lower you spark gap and get a wideband. Won't have to worry about guessing what's up as much.
  • Steve88t
    Steve88t
    • 1337
    #11
    You turned up the base fuel pressure by 6 psi. I'd guess considering the very conservative tuning of the stock ecu that you're running too rich at that point. You might consider returning the fuel pressure and boost to stock levels and evaluate performance then. If the car runs perfect you know it is related to one of the two and that there are not other problems with the car. Then you diagnose accordingly.
  • barkrz18
    barkrz18
    Member
    • 30
    #12
    oh sorry i forgot to mention intercooler with hks bov.
    The stock releif valve has been blocked off.
    i also have a fuel pressure gauge.
    and when it goes over 11psi it starts lagging in speed
  • Careless
    Careless
    • 13279
    #13
    have to say, i reduced my fuel pressure because it was wayyyyyyyyyyyyyyy higher than factory, and then i blocked off the intake filter with some cardboard to test it's temperature sensitivity.
    runs much cooler and much better than it ever did.
  • 14Psiplease
    14Psiplease
    • 148
    #14
    Have you setup you BOV properly? 11psi+ could be to much for you bov if it isnt adjusted correctly. Try increasing the spring tension.
  • BLOZ UP
    BLOZ UP
    • 2971
    #15
    The spring tension only affects operation under vacuum. The spring has to be stronger than the engine's vacuum. Boost pressure and the spring keep it closed otherwise.
    BLOZ UP.com
