Urgent: 88 Turbo Mani on 87 Turbo Car
Hi guys,
If anyone can give me a straight answer regarding the Turbo exhaust Manifolds.
I just took the uncracked turbo exhaust manifold off my 88T with the stock T25mall, and I'm curious to know if it the stock 87 Turbo will bolt upto it no problems.
I have to either get this one sandblasted, or have someone weld the 87T manifold, but I have to get it done tomorrow for sure, as the weekend is approaching.
If anyone could help, that would be great.
87Turbo T3 with stock turbo elbow
87Turbo Stock Intake hardpipe
88 Turbo manifold.
Does it work?
Thanks -
acemanSenior Member- 1566
the manifolds are identical, its the MAF to turbo hard pipe that is different.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
and intake pipe as well, as I found out.
thanks!
is there anything I can do with the T3 to brace it better so the weight doesn't crack this manifold? -
DeleriousZSenior Member- 6874
put a flex pipe on your downpipe.
1990 jetta vr6'd -
probably not, it might contribute to it, but you should have one on there anyway.
1990 jetta vr6'd -
thanks, ill keep that in mind for when I make my new one.DeleriousZ wrote: probably not, it might contribute to it, but you should have one on there anyway.
the 2.5 inch i j00ked from the 88T that i welded my O2 bung onto is 3/4 inch too long. so I can't use it anyway.
