Intake manifold leak - how common are they?
I have no idea what they did. I'm going to go over there today to talk in person. The problem with most shops is they seem very sure of themselves and don't like taking suggestions. My last few guesses is the throttle seal, vacuum hose popped off, or silicone on the charge pipe to turbo.Careless wrote: question.
did they rotate the throttle while doing the boost leak test?
i'm going to do the test this weekend and see if it's the throttle seal. i am starting to think it is.
I'm going to try your vac leak test method at the shop I use to work at and figure this thing out myself. The main thing I brought it to them for was an oil leak which they found off the valve cover gasket and valve train noise which they did agree was loud and are going to see whats going on.
Whats so stupid though is I was having this starting issue where there car would start and die off immediately unless my foot was on the gas. Vacuum leak problem huh.... Well it's rare and hasn't happened for the shop yet and I know never will. I guess it's up to me to find this shit lol.Usual Z31 suspect: Garage Queen (aka broken)
Can the engine run rich from a leaky manifold gasket or just the manifold itself a little loose?Usual Z31 suspect: Garage Queen (aka broken)
screamingfleaSenior Member- 133
Wouldn't a loose manifold cause a leak? So I will say an ambiguous "yes.""When you approach the world with the apron of a servant, you're allowed to go places you can't if you approach it with the crown of a king."~Jon Foreman
86 NA2T. Remanufactured NA engine. T3, intercooled, 13 lb boost. 3" turbo back CM exhaust w/cat, DXD Stage II clutch, blow-through w/ BOV, E-fans, short shifter. -
Being the Z31 is a MAF car, it'd be more likely to be lean from a vacuum leak, not rich.300zxturboftw wrote: Can the engine run rich from a leaky manifold gasket or just the manifold itself a little loose?
Are you sure you don't have an exhaust leak? An exhaust leak prior to the O2 can cause a hissing sound and cause the o2 to think the car is lean, and thus enrichen the mixture.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
maverickxeoSenior Member- 650
[quote]michaelp wrote:I though exhaust would sound more … mean than a hiss hahaOriginally posted by 300zxturboftwCan the engine run rich from a leaky manifold gasket or just the manifold itself a little loose?
Are you sure you don't have an exhaust leak? An exhaust leak prior to the O2 can cause a hissing sound and cause the o2 to think the car is lean, and thus enrichen the mixture. -
Well here are my conclusions after countless amounts of testing.
A) I have no exhaust leak
B) I have no vacuum leak
C) I have no coolant leak
D) I have no boost leak
E) My compression was changed from 7.8:1 to 9:1 in the rebuild process and was told by a guy from finishlineperformance (big domestic racing shop) that it might be rich because it takes in less air with higher CR and ECU sends it the same amount of fuel (I think our ECU's would compensate, but I could be wrong)
F) Main conclusion: I need Nistune to tune it.
G) Possible alternatives:
O2 sensor
Bad MAF
Possible unnoticeable silicone coupler leak
Other than this I'm stumped till I tune it.Usual Z31 suspect: Garage Queen (aka broken)
[quote]maverickxeo wrote: [quote=michaelp]Small exhaust leaks can cause a hissing noise.Originally posted by 300zxturboftwCan the engine run rich from a leaky manifold gasket or just the manifold itself a little loose?
I though exhaust would sound more … mean than a hiss haha- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Just thought I would revive this. I was out on a cruise night with some people and happened to see a z31. My car had it's rare starting problem where it's really lean and will die right away (sputtering sound). He told me he had the same problem and to replace the cap and rotor. I think this might fix my rich conditions as well. I could be having spark issues where it's not firing and is drowning the cylinders.Usual Z31 suspect: Garage Queen (aka broken)
monitor the cap while at night with the hood up and no lights around. see if you can see sparks arching through the cap. the cheap recycled plastic ones that look marbleized compared to the shiney black or brown ones from Beck/Arnley or Nissan tend to arch right through the shitty plastic.300zxturboftw wrote: Just thought I would revive this. I was out on a cruise night with some people and happened to see a z31. My car had it's rare starting problem where it's really lean and will die right away (sputtering sound). He told me he had the same problem and to replace the cap and rotor. I think this might fix my rich conditions as well. I could be having spark issues where it's not firing and is drowning the cylinders. -
Mine was an OEM Nissan part. I just ordered another cap and rotor today though. My cap contact points were a little bit messed up and I'm going to install the rotor myself this time so it will be done right.Usual Z31 suspect: Garage Queen (aka broken)
So I found a few leaks:
Coupler to throttle body was bad; replaced that and put on t bolt clamps. A few hoses underneath throttle body were off too. Fixed those, and still had a boost leak. After thinking about it for a while; I checked my boost gauge and noticed a lot of air coming from the hose. I was wondering why I could only hear it with the windows up… :nanan?re -
I did a smoke test like you guys recommended and wow does that fix your problem fast. I fixed like 5 leaks in a matter of seconds of the smoke coming out. Also popped the cap and rotor on a few days ago and have had no problem since. She idles a lot better as well (except for stupid ebay bov still sucking)Usual Z31 suspect: Garage Queen (aka broken)
