Strange Drivetrain Vibration
Over the weekend, I changed out the subframe bushings on my beater Z. Just the standard drop the rear subframe and replace the bushings. There were no complications. On my way to work this morning, I noticed the car has developed a coarse drivetrain vibration. It only occurs in gears 3rd and above and only when accelerating. I'm stumped at this point. Any ideas?
NissanEggSenior Member- 5220
Maybe it was there all along and couldn't tell on the old bushings. :-?
shromySenior Member- 2189
mark the drive shaft? or cv's for that matter?Hmmm, Whats next?
84ZXT -
Well its all gone from bad to worse. I got new CV's for the car but one of them WILL NOT clip into the diff. What a massive pain in the ass!
Is the c-clip on the end of the axle missing or damaged?
I had a cv axle on my 91 SE-R that had a too small diameter c-clip and the axle popped out of the trans 2 miles from the house. Luckily I had LSD to get me back to the house to put the old busted one back in.
OT: :? Reminds me of when I broke an axle on my maxima, and makes me sad…because I had no LSD and it stopped goingNissanEgg wrote: Is the c-clip on the end of the axle missing or damaged?
Wheel Hop FTL
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
when you lowered your control arms at an angle to remove the rear springs, did you over-extend the half-shaft at an extreme angle?
I've learned that the best way to go about dropping the subframe or letting the control arm droop down far is to pop the inner half-shaft tension by prying on the diff where the half-shaft goes into the diff. This will break it's bond free and allow it to slide out sufficiently enough to do the rest of the work.
You may have over-extended the angle at which it can operate and it may have popped something loose inside. even @ 20 years old, the boot will not rip but you can do considerable damage doing so. -
I'm going to have it towed to a friends house to check out tomorrow. Will update after we take a look.
