chts harness
JoshVG30ETMember- 74
chts harness
ok so i went to the dealer to buy my chts…and i had asked for the sub harness to cuz i wanna replace it…but they told me that i couldn't just buy the sub harness…they said i would have to buy the whole wiring harness…
…does anyone know where i can get just the sub harness?
jn1czSenior Member- 1520
Any dealer should have it. You can def get one from http://www.nissanparts.cc.
Part #24079-01P00
Personally I wouldn't worry about it unless yours is known to be bad. -
FirehawkSenior Member- 950
The harness often go bad at the sensor. Most cars need them, but think that it is only the sensor.jn1cz wrote: Any dealer should have it. You can def get one from http://www.nissanparts.cc.
Part #24079-01P00
Personally I wouldn't worry about it unless yours is known to be bad.Chuck Stong
http://www.300-plus.com
I recommend making a new harness (ie ripping the connectors off and soldering in new wire) with tinned 18awg cable, less suceptible to corrosion
