Setting timing belt tension
JSMSenior Member
- 279
Well tension set. I ended up taking a pic before I took tensioner off. It ended back in the same spot.
Quick video of first start. Seems quiet to me.
https://youtu.be/JCdEEaaAkWM
JSMSenior Member
- 279
No. Used the old pic and feel method. -
BLOZ UPSenior Member
- 2971
Hello z31p
Originally posted by JSM View PostAnyone recall if the tensioner nut had a lock washer? Mine did not. Did anyone use loctite on the nut? I wonder why they give a range for the torque on the nut?
I ended up using the deflection and twisting methods though it seems like such an unscientific method (compared to say, torque when twisting the tensioner itself), but I've never broken a belt or had any issues.BLOZ UP.com
albionwanderer86Senior Member
- 176
I just found this video on Youtube put out by Gates. I'm not entirely sure what VG30 or VG33 he is performing this timing belt replacement on, but he does a very good job of explaining components and what he is doing when replacing the timing belt and tensioner. Hope this helps someone.
https://www.youtube.com/watch?v=vd5y9teII9E1985 300ZX Z31 2+2 VG33ET (running!) -
DunkineSenior Member
- 255
Oil filter spins on block, so vg30 most likely. 33's are remote mounted (not sure if all are though).
Great video. That's a trick little tension tool, I can't seem to find anyone selling Gates' kit. They have one listed on Gates' site, but I don't see a product # to look it up by.
http://www.gates.com/products/automo…tension-tester
http://www.gatesunitta.com/timing-belt-tension-tester
Has anyone used this universal one?
- 2971
Originally posted by albionwanderer86 View PostI just found this video on Youtube put out by Gates. I'm not entirely sure what VG30 or VG33 he is performing this timing belt replacement on, but he does a very good job of explaining components and what he is doing when replacing the timing belt and tensioner. Hope this helps someone.
https://www.youtube.com/watch?v=vd5y9teII9ELast edited by BLOZ UP; 05-16-2019, 09:02 PM.BLOZ UP.com
- 1 like
