Car wont start After short (Fire)
kloozMember
- 41
I had a fire in my car a while back because of a wire that i didnt put through a grommet it shorted out and blew my main fuse link for my battery. So my car wouldnt start so i got a brand new fuse link from courtesy parts. I put it in and still nothing. I have fixed all the visible damage done by the fire there were no visible burns on any of my other wiring. I have checked everything. I have fuel but no spark. Also, right before this happened i had just put a brand new rotor and cap on. It was the test drive after the cap. I can put pictures if needed.88' Turbo - Stock VG30 - HE351 - 3" Turbo Back - Turbo XS RFL BOV - Hallman MBC - Eibach Lowering Springs w/ Tokico Illuminas -
88sinZSenior Member
- 2019
FrozenZSenior Member
- 584
What he said. I'm pretty sure that people have pooched their ECUs with shorts too. I would try to find a known good ECU first because it's relatively easy to test, finding a known good 88 harness may be a bit of a trick. -
kloozMember
- 41
there is no visible harness damage in my engine bay i have inspected everything. does anyone know if nistune can repair ecus when you send it to them for there software,88' Turbo - Stock VG30 - HE351 - 3" Turbo Back - Turbo XS RFL BOV - Hallman MBC - Eibach Lowering Springs w/ Tokico Illuminas -
kloozMember
- 41
im going to go nistune anyway so i just need to know if i need to buy a working ecu or can i send them mine.88' Turbo - Stock VG30 - HE351 - 3" Turbo Back - Turbo XS RFL BOV - Hallman MBC - Eibach Lowering Springs w/ Tokico Illuminas -
TrbulntSenior Member
- 347
Unless you ohm'd out every wire you start lol may have a broken wire or other shorted device. I wouldn't waste the money sending a suspected faulty ecu without contacting Nistune to ask them directly.
