Question
1986zxtSenior Member
- 482
Question
My car is losing one qt of oil every 400-500 miles. No leaks or drips. Car emits a puff of smoke out of the exhaust on start-up and anytime turbo is in boost. The exhaust tips are black. Obviously the oil is being blown out the exhaust.
My mechanic seems to think valve stem seals. Does this sound reasonable? Any other possible culprit?1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
mtherkampSenior Member
- 243
Could be either that or turbo seals. I guess it could also be a pcv problem if the valve is stuck open under boost it could draw oil into intake that wayButter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard." -
- 482
Turbo was just replaced, rebuilt by Joel. Was wondering about PVC. It's getting worse pretty quickly. Will be getting into it this weekend.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
nismo kidSenior Member
- 785
What do the back side of your valves look like? If the valve stem seals are indeed bad the valves will have build up on the backside & stem of the valves. Remove your exhaust manifolds & intake manifolds so you can peak inside the ports. You could also snake a bore scope through the lower intake manifold. Is turbos compressor wheel still clean or covered in oil? Personally I'd do a Fuel injection service (BG or equivalent), replace all the valve stem seals then continue to monitor it. This would probably be the most cost efficient solution.Originally posted by Racinjitter:lol: Those of us who say A/C FTW all have a g/f or wife. ac+women=more quiet=possibility of sex. -
ac+women=SUPER BITCHING=no sex. -
- 482
Originally posted by nismo kid View PostWhat do the back side of your valves look like? If the valve stem seals are indeed bad the valves will have build up on the backside & stem of the valves. Remove your exhaust manifolds & intake manifolds so you can peak inside the ports. You could also snake a bore scope through the lower intake manifold. Is turbos compressor wheel still clean or covered in oil? Personally I'd do a Fuel injection service (BG or equivalent), replace all the valve stem seals then continue to monitor it. This would probably be the most cost efficient solution.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
- 482
Forgot about this post. Two of the valve stem seals on the driver's side were shot.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
- 482
… and it is still using mucho oil. Methinks I had a detonation issue that I was not detecting and over time, POOF. Anybody know of a reputable shop in or around the Nashville, TN area for a rebuild ? The guy that has been working on my car, I believe, has surpassed the limit of his abilities.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
Augustus MaximusSenior Member
- 1739
Get a VG30e from a Maxima or Pathfinder and have that swapped in.Cha iro
Ski300zxSenior Member
- 454
you can pull off the pcv hose while the engine is running to check it… should have vacuum where the hose goes. or take it off and shake it, see if its gummed up. take off the intake tube where the breather goes in and see if you see oil residue on the intake, thats a sign of a bad pcv. if you aren't sure, i think they cost 4 dollars, i would just change it.
as far as valve stem seals, you dont need to take the head off to change them, just remove the valve covers, then remove the rocker arms. use a leak down tester to put compressed air into the cylinder. this will hold the valve up. I use about 60psi, that should be fine. as a cheap insurance policy, rotate the engine so that piston is at least near top dead center. that way in the valve accidently falls down, it will just lay on top of the piston rather than falling in and now you have to pull the head.
use an overhead valve spring compressor to compress the valve and remove the keepers, retainer and spring. remove the old seal and install the new one. repeat for each cylinder, rotating the engine to tdc before u take out the keepers.Ride it like you stole it…
1986 300zx NA2T - CM 3" turbo back, Pathy 3.0 Engine, Custom cold air intake, 255lph Walboro, T3 turbo, 90 shot of nitrous, 30A trans, 88t LSD, Poly everywhere, SS brakelines. 288whp 336wtq
2001 YZF600 - Sold for Nitrous and Exhaust Upgrade…
1993 Toyota Corolla - The invincible daily driver, off to greener pastures.
2002 Nissan Maxima SE - New daily driver
