Slight Hesitation
Slight Hesitation
This is an issue that has been nipping at me. If I give the throttle a good pump, my engine will hesitate less than a second before revving up. Its very short lived but its certainly there. If I slowly get on the throttle, everything is normal, so it only occurs when I pump it. I checked my codes and got 21 (Coil wtf?) and when I rechecked them, I got a 44 code. Any ideas or suggestions would be greatly appreciated!
1SIKZ31Senior Member- 1236
This has been an on-going problem with Z31's from MY EXPERIENCE.
My Z31 did this, my friends did, and my other friends did.
I personally came to the conclusion that its because of the stock AFM Placement. I think that because it has to draw air through the charge pipe and through the compressor housing as well as against a ALMOST stalled compressor wheel causes the "delay".
BUT I also think im IN-correct because my friends VG34 Z31 does not do this, it is INSTANT throttle response without that hesistation you speak of!
Now when I got my intercooler, this hesitation got even worse!
I went from 1-2 feet of plumbing before the throttle body to over 5-8 feet (Intercooler piping) of piping!
My Hesitation got about 50% worse.
I then upgraded to Z32 AFM and placed it 1 FOOT before the throttle body and the throttle response got 10x better BUT that "hesitation" is still there…
Heres the kicker.
The ONLY things my car has to run is:
Fuel temp sensor.
MAF (AFM)
CHTS
Crank Angle Sensor
TPS
THATS IT.
Sooo… I guess its a programming issue going against the Nissan engineers rather than a Vehicle issue…
Then again maybe someone more knowledgeable can chime in :baton1SIKZ31 -86 SlickTop- R.I.P. 03/01/10 … Parted out :-(
Guest
it seems to be a problem with alot of cars. my Zs do it my jeep does it friends 96 ranger does it etc. etc. etc probably does have to do with the maf. -
Domdogg123Senior Member- 491
