ignition module transistor
300zxandersonJunior Member- 20
ignition module transistorError code 21 is popping up. I think i need to replace this component. Does anyone have a spare one of these. The only one I can find is over $100. If you think the error code 21 is something else please let me know. -
zachary.ardBenevolent Dictator- 1629
Well - code 21 could be a couple of things.
If you think its the PTU (Power Transistor Unit) here is a how-to to use a newer, upgraded PRW-2 unit.
https://z31performance.com/forum/z31…ransistor-unit
If you think the issue is a faulty Crank Angle Sensor, they are available here -
http://store.acadianasportscars.com/en056-0002Chicks dig me, rust fears me.
