Huge Ticking when Hot idle
z31xacJunior Member- 5
Hi, I always had the normal lifter ticking at startup when cold for 2-3 seconds but now when I'm back from a ride I got a huge tick that really sound like crap at idle (like a diesel truck) (not the startup sound). The noise stops at 1000 RPM. It's not the injectors ! I hear them at 1000RPM… the rattle is 5 times louder. Oil Pressure at 2kg on highway (30lb on US gauge), 15lb minimum. Using 10w30 high mileage. I'm really not planning repair (job, kids..). What oil / additive could I use to help if possible. Engine is 291 000 KMs, did run on fresh oil for the last 22 years ! (87NA) -
Are you sure it's not an exhaust leak due to a busted manifold stud, or cracked manifold.? They can sometimes tick and mimic a lifter noise.
You could try and run some SeaFoam additive in the oil just before a oil change to help dissolve any gunk in the lifters.
However the side effect of doing this means that you may be dissolving anything that is keeping a already weak seal from sealing anymore.
Disclaimer, i've not done this myself, i get a startup tick that goes away pretty quickly.
If the solvent helps, you might consider switching to synthetic oil if you haven't already done so.
shromySenior Member- 2189
id be willing to bet a lifter has collapsed
.Hmmm, Whats next?
84ZXT -
NissanEggSenior Member- 5220
Sounds like a weak and collapsed lifter. Only issue is determining exactly which one is making the noise.
So that could possibly damage the engine right ? Is it something we see often on these engine (total fail/damage) ? (Because I can live with the noise).
By the way it is NOT that noise:
https://www.youtube.com/watch?v=c2T7yUPW2T0
It is more like if you throw some small bolts in valve cover and hear them rattling around.. -
ZuphoriaJunior Member- 26
At 00:30
https://www.youtube.com/watch?v=HOrpvcwJfSI
Pressure when cold at 30lb, 15 when hot.
Noise only when hot and idle.
