Will the vg30dett oil pan fit the vg30et?
z31 maniacJunior Member- 30
Will the vg30dett oil pan fit the vg30et or vice versa? Has anyone swapped these oil pans before? -
260DETSenior Member- 537
Played around with swapping this sort of stuff 15 years ago so memory.......... Fairly sure it will fit but get the oil pickup too. If someone else says 'no' then take notice of them. -
The dett crankshaft snout ( front end where the oil pump and crank pulley are) is larger in diameter than the et. Would that be a hindrance or does it not matter?
