Timing belt troubles
samshadowSenior Member- 176
Hi Everyone,
So I had changed my timing belt and have been having issues with noise. I can get the belt to sound fine without the covers on. Then once i put the lower on it sounds fine until I torque crank. Then i get the noise in the video. Car sounds fine at idle but once you rev it you get the whining noise. I have right around 1/2 inch deflectionGeniet van je favoriete video's en muziek, upload originele content en deel alles met vrienden, familie en anderen op YouTube.
DunkineSenior Member- 255
Did you measure the deflection with the crank tight? Back the tensioner off a little and see if it goes away. -
Timbo_021Senior Member- 514
That belt looks as tight as a nuns cunt. Should be more around 15-20mm deflection when cold. As it warms up it will tighten up.Straya, +61
