link129 link130 link131 link132 link133 link134 link135 link136 link137 link138 link139 link140 link141 link142 link143 link144 link145 link146 link147 link148 link149 link150 link151 link152 link153 link154 link155 link156 link157 link158 link159 link160 link161 link162 link163 link164 link165 link166 link167 link168 link169 link170 link171 link172 link173 link174 link175 link176 link177 link178 link179 link180 link181 link182 link183 link184 link185 link186 link187 link188 link189 link190 link191 link192 link193 link194 link195 link196 link197 link198 link199 link200 link201 link202 link203 link204 link205 link206 link207 link208 link209 link210 link211 link212 link213 link214 link215 link216 link217 link218 link219 link220 link221 link222 link223 link224 link225 link226 link227 link228 link229 link230 link231 link232 link233 link234 link235 link236 link237 link238 link239 link240 link241 link242 link243 link244 link245 link246 link247 link248 link249 link250 link251 link252 link253 link254 link255 link256 link257
NA2T idle air control wiring questions
  • albionwanderer86
    albionwanderer86
    • 176
    I have a question pertaining to wiring up Turbo idle air components on an NA2T build. Let me preface by saying that I do not have the corresponding connector from my Turbo parts car, and therefore I am going to be using the NA connector, simply changing out the wires. I have read the write-up on Xenonzcar.com, but I am a little confused about the "other" two wires. I understand, and have picked out of the connector, the necessary blue and black wires that need spade connectors. My question is about the remaining two wires: the yellow w/h green stripe and the black. I removed the connector from the Turbo component, but all I found there were two black wires. I need to know which wire corresponds to which.
    The blue and black wires "picked" out of the connector, leaving the yellow w/h green stripe and black still encased.
    Turbo idle up component minus connector. Both wires are black?
    Simply put… I need to know which of these black wires goes to the yellow w/h green stripe wire, and which one goes to the corresponding black. I've tried to check the FSM, but I can't find a clear cut explanation.
    1985 300ZX Z31 2+2 VG33ET (running!)
  • FlawleZ
    FlawleZ
    • 1971
    Is your EFI harness from an 85 NA?
    545 RWHP & 540 RWTQ
  • albionwanderer86
    albionwanderer86
    • 176
    Yes, the harness is from an '85 NA 2+2. The Turbo idle components are from an '85 Turbo automatic, California emissions (if that matters).
  • Dunkine
    Dunkine
    • 255
    Looking at the FSM E.C.C.S. wiring diagram EF & EC-8, it shows Y/G & B going to the FICD Solenoid and L (blue) & B/W going to the Aux Air Ctrl Valve.
    Is that what you are going by?
    On Xenon, is he saying to hook up the Fast Idle Control Diagram? For when you turn A/C on, etc. Or the AAC valve?
    Might be easier to ask him direct on his FB page: https://www.facebook.com/groups/xenonzcar/
  • albionwanderer86
    albionwanderer86
    • 176
    #5
    Yes. That sounds correct. My issue is exactly which wires the yellow w/h green stripe and black wire match up with. Both wires coming off the FICD solenoid side are black, which is what is confusing me. Obviously the yellow w/h green is going to be hot, while the black will be ground (going by standard wiring logic, which could be wrong, of course). Unfortunately, I don't know on the FICD solenoid side which wire corresponds to hot and which for ground. The write-up I read doesn't cover those two wires at all, just the blue and black w/h white stripe.
    • Dunkine
      Dunkine commented
      I'm no electrical engineer, but polarity may not matter.
      "If the current in the solenoid is now reversed, the magnetic field of the solenoid will reverse but, since the induced polarity of the plungers will also reverse, the direction of the pull on the plungers will be unchanged."
      From: http://www.solenoid-valve-info.com/s…-polarity.html
      Which might be why both wires are the same color.
    • albionwanderer86
      albionwanderer86 commented
      I wondered if polarity mattered, maybe it doesn't. Like I said, I can't find anything written up about these two wires, save for you use them on the FICD. I guess I could always apply power and ground to the wires on the solenoid and see if I get a response either way… thanks for looking into it.
