I’ve torn apart my z and searched the forums as well as talked to many of my friends for the past 2 weeks about this but basically I’m not getting any spark once so ever all the way to the coil I’ve tested, i have a 1987 300zx na m/t and i swapped a 1985 300zx turbo a/t in and i deleted everything that wasn’t necessary (ac, power steering, all vacuum lines/pumps, aiv aic selinods, icv, egr) when i pulled my engine everything worked fine, now that i have my 85 motor in i hook everything up and i have the started terminals on backwards or something to the point where it wouldn’t start. I fixed this i try to start it with my 85 distributor and 87 coil and power transition all working. Still no spark injectors not firing either, so buy new ecu check fuses and still nothing, I’m thinking i fried my harness when the starter terminals were on backwards, but i wanted to see what you guys thought, i had no continuity On the CAS pins when 8 and 17 pins in ecu were looped together, i really just want my car to run again it’s been 7 months now and I’m not sure what to do anymore. ANY HELP WOULD BE GREATLY APPRECIATED
No spark no start
Did you visually inspect the fusible links or test them with a continuity tester? Also did you check all the fuses on the driver side?
Originally posted by JSM View PostDid you visually inspect the fusible links or test them with a continuity tester? Also did you check all the fuses on the driver side?
You should check them with a tester. I’ve seen them look fine and test bad. This is on a 280zx but just bumping causes it to fowl.
Those links prevent everything from getting power.
https://youtu.be/_0ESALmKebs
Also there are a couple main EFI relays behind the black cover on the fender frame rail behind right by the fusible link box.Last edited by JSM; 07-05-2018, 06:43 PM.
