1984 Datsun Nissan zx turbo piston damage
ETz31Junior Member- 5
Got the car off a friend for $150 it ran and drove before I pulled the engine and trans to freshen up. Pulled the heads and 2 cylinders on passenger side have damage around the lip. We're can I get oem grade Pistons with out having to pay a arm and a leg from Nissan. And does anyone know what caused this. A lean issue? -
bonfire79Senior Member- 223
possible detonation i would think. you can get stock piston kits for a fairly good price if you look around. i got a set from rockauto.com for my NA, slighty bigger but to OEM specs. can't remember the brand. the kit was around 150 bucks maybe a bit more. they have been working great.
Bon -
DunkineSenior Member- 255
Might not be able to get them from the dealer anymore. Nissanpartsdeal is showing turbo piston with pin for $66.77, but with the Limited Availability caveat.
If you are just trying to build a cheap daily driver or fun car you could try to get a pair used. Another option would be to swap in an NA bottom end or even a complete NA engine for a little more compression.-
#3.1dbruce commented10-23-2018, 10:02 AMAren't the z32tt pistons and rods useable in the z31t ? Except for a resulting lower compression ratio ? -
That's what I've heard for the TT pistons. I think the N/A are raised in the center, so they don't work, IIRC.
Engineered Performance EPR has a fire sale until the 31st. From their facebook post:
"SOHC VG30 & VG33 guys listen up!
Running a fire sale on my custom SOHC pistons & rods with piston coating (2 Stg) Sale ends October 31, 2018. Piston orders are 4-6 week lead time FYI.
Kit includes:
EPR Custom SOHC Pistons (any bore size & compression)
Scat Forged H-Beam Rods (ARP 2000 Rod Bolts)
EPR 2 stage piston coating (tops & skirts)
FREE SHIPPING
EVERYTHING LISTED $1550 SHIPPED"
