Engine throwing out smoke and runs rough.
BarnFind_ZJunior Member- 9
So I bought this Z. I got back to a garage that I work at, changed oil, Spark plugs, and ignition wires. I try and start it up, it started but I have to hold on the throttle to keep it from turning off, and the car throws out a lot of smoke. I run it for a while the car still has smoke coming out of it. All of the bad gas that was in there is gone, I put new 93 octane gas in, 5 gallons gone after I run it around of a building twice. Now I don't know what to do. What should I do to get this motor working right?Tags: 1987, engine, non turbo, smoke
dbruceSenior Member- 258
"5 gallons gone after I run it around of a building twice." So the "smoke" is unburnt gas ? that's o2 sensor and MAF or timing or bad spark or lots of things …
1. get a manual ( they are online pdf files )
2. check the codes on the ecu
also what year/model is the Z ? turbo ? non turbo ? -
JSMSenior Member- 279
What color smoke, black like gas blue like oil or white like water? -
I got new plugs in, the smoke is white when I start it and when I let it run for a while.Originally posted by dbruce View Post"5 gallons gone after I run it around of a building twice." So the "smoke" is unburnt gas ? that's o2 sensor and MAF or timing or bad spark or lots of things …
The car is a 1987 N/A -
Check your oil. If itâs starting to look milky itâs a head gasket. Still may be a head gasket if itâs not. Also when itâs cold, take the radiator cap off and check for bubbles as itâs runninf and look for like in the radiator fluid. Assuming the smoke is white.
Both head gaskets were bad on my car and that is exactly how it ran. -
mwolvinmSenior Member- 249
Do a compression check. It'll tell you which, if any cylinders are bad.--------------
Legal stuff:
**Nissan Employee**
not legal stuff:
'00 Corolla-- kids car.
White smoke = burning coolant. Unfortunately, Z31s are known to have headgasket failure problems. A compression test won't always show bad headgaskets, you really need to do a leak-down test. If you don't have access to a compression tester or leak-down tester, you can try a block tester. You can get the kit from an autoparts store for fairly cheap. A block test tests your coolant for exhaust gases, which shouldn't be there if your headgaskets are healthy. Do you know the history of this car from the previous owner?Last edited by albionwanderer86; 11-26-2018, 07:27 PM.1985 300ZX Z31 2+2 VG33ET (running!) -
I don't think Z31s are prone to blown headgaskets on a whim like cough* subarus or early production last gen Civic Type R's*.Originally posted by albionwanderer86 View PostWhite smoke = burning coolant. Unfortunately, Z31s are known to have headgasket failure problems. A compression test won't always show bad headgaskets, you really need to do a leak-down test. If you don't have access to a compression tester or leak-down tester, you can try a block tester. You can get the kit from an autoparts store for fairly cheap. A block test tests your coolant for exhaust gases, which shouldn't be there if your headgaskets are healthy. Do you know the history of this car from the previous owner?
Mistreating any car will lead to blown head gaskets. Overheating in particular.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
I agree, but I also know of countless Z31s that have had blown headgaskets… just look on Craigslist and Facebook Marketplace, a good deal of them for sale list blown headgaskets. Now, 90% of the reason for this is owner error, that is true. But, being that this is a USED car, it isn't too far of a stretch to think that the previous owner did the no-no of overheating it.1985 300ZX Z31 2+2 VG33ET (running!) -
So update on the 300.
- The car still smokes like crazy
- But it runs strong
- White smoke smells like burning oil
- Idle is still bad on the car, needle tends to fall when the motor get revved up
-Lastly, the car is staying cool, no overheating issues
Thank you to everybody that has answered on this post, I hope the people who's helped me diagonoised the problems stay until the car is finished. -
-Update
I have given up on the car, I don't have anytime for it, the last thing I did on the car was prime it. Instead of keeping the existing motor, I thought of switching it for a used vg30.
Now I'm looking to sell the car, along with an 88 N/A GL that runs.
I'm about to buy an 88T GL a friend of mine has in the two weeks or so.
Thank you everybody for the help and anyone is interested in two N/A Z31's one that has a lot of rust, but runs with smoke and one with rust and a motor that runs strong, PM me. -
z31_chrisJunior Member- 17
Use a metal wire brush and scrape off the contacts of the distributer cap. You might want a new one and rotor eventually but that is a good test -
FlawleZSenior Member- 1971
Did you ever do a compression test? Change of fluids? It sounds like you had a bad head gasket.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
