Exhaust smells of heavy gas.....
SpazzymcgeeSenior Member- 108
Sooooo can not seem to figure this situation out for the life of me.. Got new rack&pinion put in and when I go to start up I get the usual normal startup but a HEAVY smell of fuel out the back....
Any thoughts?
JSMSenior Member- 279
Doubtfully related. -
Well yes I know this but ideally what would cause this smell to randomly just start. I've never had this happen on any of my other Zeds. -
Two thing off the top of my head:
Leaking FPR: A failed diaphragm can cause this. Pull the vac hose from the top of it and see if it smells like raw fuel.If it does, replace the FPR.
Leaking injector: Inspect the sparkplugs and see if one of them are wetter than the others with raw fuel.
Or install new plugs and take a drive for a few miles then pull them and see which one fouls first.
The FSM has a injector test procedure too,
My 84T has a leaky fpr that I've been neglecting replacing until the weather warms up.
- 2 likes
Failed CHTS too if itâs just exhaust fumes your smellling -
drnict61Junior Member- 14
DunkineSenior Member- 255
